How Can I Make The Throttle Response Less Aggressive Hayabusa
21 replies to this topic
#16 Ethel
  • 25,416 posts
Posted 24 December 2012 - 09:10 AM
how about changing the cable connection plate on the throttle body to a larger one or a snail shaped (helical) shape so that the throttle response is less aggressive to pedal movement?
That's what they did for the Metro. You need more pedal travel, or it biased to give more at the lower end. Better if the snail cam is on the pedal side of the return spring, it'll improve the feel. If you wanted to try something electronically you could make a 2 stage geared throttle and use a solenoid to lock the gears.
#17 joss
joss
  • 143 posts
Posted 02 January 2013 - 04:58 PM
Thanks for that would I have to fabricate the snail cam or can I purchase one that will do the job (oh happy new year to you all)
#18 2000lukey
2000lukey
  • 70 posts
Posted 02 January 2013 - 06:33 PM
Just a thought does your cable go via a adaptor bracket / lever, located near o/s front bottom a arm mount?
As the idea of that is to adjust throttle pedal travel, if you have the bracket there I have a spare zcars lever as I did not need it with my non bike engine set up.
You may well already know about this so please ignore if that's the case.
Luke
#19 mk3 Cooper S
mk3 Cooper S
  • 5,569 posts
Posted 02 January 2013 - 09:54 PM
This will definately work.
You will be able to make it so that the throttle moves less in relation to pedal movement intially and more to pedal mobement towards the end of the pedal travel.
Yes it will work,
Or change the pedal ratio but that will possibly require more overall pedal movement.
#20 joss
joss
  • 143 posts
Posted 12 January 2013 - 10:30 PM
I have adjusted the pedal ratio and it seems more easier on the response now thanks
#21 edsmini
edsmini
  • 357 posts
Posted 12 January 2013 - 10:34 PM
good to hear joss, that will save you giving it too much welly on the roundabouts and making an arse of yourself when you cant catch the rear end :-)
Ed
the wheels look good .
#22 joss
joss
  • 143 posts
Posted 15 January 2013 - 07:41 PM
Oh I done that a few times now I am a prime arse and enjoying it Ed
