Im at the stage of fitting the heelboard and would like to ask your opinion on my method of aligning it correctly to the front end subframe mount position.
My opinion is that it needs a fixed 'datum' point to be aligned to, to avoid the infamous crabbing effect.
Therefore the main fixed point would be the front subframe mount on the X-member bulkhead.
From this point, if the rear subframe is accurately aligned and square to it, there should be no issues of crabbing or rear end steer.
Since the mini is essentially a hand built shell with no real reference points on the bodywork, then the only fixed place that is relevent is the front subframe and making sure the rear subframe is 'square' to it etc.
Ive very accurately constructed a piece of steel which is fixed to the front X-member by bolts from the inside and then by running a line or measurement from each end down to the heelboard corners should effectively square the heelboard to it.
At the moment i have 10mm of mis-alignment - left side is 163.5 cm, and the right is 162.5 cm from the measurement point at the bulkhead X-member.
Is 10mm difference going to be a cause for concern or is it acceptable?
Have a look at these pictures to see what im on about -
I hope these explain what im trying to achieve.
Many thanks in advance.
Edited by antcole, 01 January 2013 - 02:01 PM.
