My Pro-Motive Adventure.... This Could Be Interesting!
97 replies to this topic
#31 duds100
duds100
  • 231 posts
Posted 12 July 2013 - 11:15 AM
Well my painter is a little bit tied up with other things so I decided to use a rusty clubby I have as a mule to make sure its all is as it should be...
Now the fun wiring! Yay!
I hope to have it fired up next week. On a side note where and how have people sorted the fuel return? Back to tank or just back inline?
Build is looking good! looks like a 5PW injection motor to me, the same as I am running. Fuel return I have run all the way back to my ally tank in the rear. The fuel really flies back to the tank at engine idle (i`m using an electric V8 TVR bosch injection pump, not the R1 pump). You could do the same or use an MPI mini tank and fuel pump, but again I would run the fuel return back to the tank.
#32 domdee
domdee
    Formally known as dominicdee
  • 1,183 posts
Posted 12 July 2013 - 11:41 AM
nice build
good to see zcars alternatives
#33 blunder
blunder
  • 120 posts
Posted 13 July 2013 - 12:10 PM
Which side is fuel into the rail if looking at the above picture?
#34 blunder
blunder
  • 120 posts
Posted 14 July 2013 - 03:05 PM
Well managed to do the wiring and get it turning over on the key, after figuring out I needed to supply power to the mini too! Lol... Deer....
Still plenty to do to get it drivable for a shack down, fuel piping, brakes and cooling to name but a few!
#35 blunder
blunder
  • 120 posts
Posted 15 July 2013 - 02:45 PM
More progress...
well on the mock up body test rig!
Managed to make it run on a drink or juice as awaiting my fuel pump. Has everyone returned into the tank or plumbed back in tank side of the pump?
ps. Sounded like a beast without the exhaust on!
#36 racerlike
racerlike
  • 436 posts
Posted 15 July 2013 - 03:07 PM
As someone mentioned above an Mpi tank is the simplest solution. That's what I have done and the fuel returns directly to the tank
#37 blunder
blunder
  • 120 posts
Posted 18 July 2013 - 01:36 PM
It lives.... Started and running! Sounds fun!
#38 kjwithers
kjwithers
  • 62 posts
Posted 19 July 2013 - 05:52 PM
Video??!!
#39 blunder
blunder
  • 120 posts
Posted 22 July 2013 - 01:00 PM
[ur] [/url]
Edited by blunder, 22 July 2013 - 02:09 PM.
#40 kjwithers
kjwithers
  • 62 posts
Posted 22 July 2013 - 04:28 PM
Awwwsome, sounds great!
#41 blunder
blunder
  • 120 posts
Posted 27 July 2013 - 11:38 AM
Ok... It starts it runs and have driven around the block.... I seems a little hesitant and jerky on throttle.... This usual? Also not overly great to start? Maybe that's a fuel pump thing? But not the smooth at idle either are they constant or wander in the revs a little?
#42 clovus
clovus
  • 231 posts
Posted 28 July 2013 - 03:14 AM
Good work mate. Will be really keen to hear how it drives once you're all sorted.
#43 blunder
blunder
  • 120 posts
Posted 28 July 2013 - 11:38 AM
Think I may need to get the throttle bodies balanced/checked and probably need to check the vac pipes make sure they are all hooked up...
Read up this can cause rough idle like I have, anyone have any experience of this?
Drove it today though..... Goes like s&*t off a shovel! Lol
#44 blunder
blunder
  • 120 posts
Posted 01 August 2013 - 01:28 AM
Question for the guys running this set up.... What height off the ground is your sump?
#45 racerlike
racerlike
  • 436 posts
Posted 01 August 2013 - 02:40 PM
I'm on 10" wheels and the sump is about 3.5 - 4" from the deck.
Worryingly low if I'm honest.
