My Pro-Motive Adventure.... This Could Be Interesting!
97 replies to this topic
#76 blunder
blunder
  • 120 posts
Posted 04 October 2015 - 03:44 PM
Ok doing final fit ups on parts and it's looking tidy!!! Unlike my garage 😋
Attached File  image.jpeg   85.78K   32 downloads
I played around with the the shifter and shaped the base and fitted.
Attached File  image.jpeg   54.45K   20 downloadsAttached File  image.jpeg   40.07K   13 downloads
Exhaust offered up and checked, might have to trim centre section as the tip sticks out a bit too much and think they will moan when inspected.
Attached File  image.jpeg   64.15K   25 downloads
Also started to pipe in oil cooler and accusump. Just a quick question: how high do you think I can go with the oil cooler and accusump? Was planning on fitting accusump on bulk/fire wall and oil cooler as high a normal mini radiator but a slim one!? What you guys think? Not too high???
#77 blunder
blunder
  • 120 posts
Posted 23 October 2015 - 01:57 PM
Car got a quick strip down for a paint issue to be rectified!
6498E242-D0F0-44C2-8D21-8978C1BB6B2C_zps
Then the roof has a rub back prep and respray
#78 blunder
blunder
  • 120 posts
Posted 23 October 2015 - 02:04 PM
8ACB631F-127C-4647-B147-D0BA6D7BCFAC_zps
Edited by blunder, 23 October 2015 - 02:07 PM.
#79 blunder
blunder
  • 120 posts
Posted 23 October 2015 - 11:45 PM
Ordered some arc Angel panels too! Has anyone used these? I want light but hidden so went gel coated all carbon!
#80 jonny f
jonny f
  • 1,485 posts
  • Local Club: Boxhill Mini Club
Posted 24 October 2015 - 06:27 AM
They're the cheapest for a reason. Awful service.
#81 blunder
blunder
  • 120 posts
Posted 24 October 2015 - 11:48 AM
Product???
Service is a variable, product is what I was asking. Thanks for your view
#82 andy86
andy86
  • 41 posts
  • Local Club: Cymru minis
Posted 24 October 2015 - 12:25 PM
the quality of finish from arc angels parts I've had have been really good but you do need to keep onto of them i waited six months for my carbon fibre doorcards
#83 jonny f
jonny f
  • 1,485 posts
Posted 24 October 2015 - 02:04 PM
Again they're the cheapest for a reason lol.
I'm still waiting for a replacement engine steady that broke in February. I email them every month and get the same reply 'be out to you next week'. Yea right!
The doors, boot, bonnet have been reasonable they took quite a lot of prep to paint them. One of the door skins came away at the bottom recently though. Not the most thought out design, had to glass it back on properly and paint it again.
#84 blunder
blunder
  • 120 posts
Posted 24 October 2015 - 04:23 PM
Carbon or fibreglass? I went carbon!
#85 racerlike
racerlike
  • 418 posts
Posted 24 October 2015 - 06:10 PM
I have carbon door cards. Fit was good I thought although finish wasn't perfect - few pockets across the surface however I waited a long time for them so decided to keep them and accept the imperfections.
The fibreglass bumpers were good though.
#86 jonny f
jonny f
  • 1,485 posts
Posted 25 October 2015 - 06:20 AM
Friberglass maybe carbon is better I would of thought its same mould
#87 blunder
blunder
  • 120 posts
Posted 02 December 2015 - 01:06 PM
Just rehashed my modified reverse system. Got rid of the promotive cable as I could see me getting fed up trying to feed the clutch whilst pulling on a cable waiting for the dog reverse box to fall in........ So........
Removed the cable and fitted a linear actuator with control board. I basically set it up to work off an on/off toggle switch to fit in with the other dash items(but fitted with a cool flip stop missile cover). I used a dpst(double position single throw) switch and on the other side fitted a small 12v buzzer so I know I'm in reverse! The linear actuator and board mean you can vary limits, accuracy, speed and stall time. This means you can flick the switch and the actuator will keep pulling in or pushing out( I have it set at 3 seconds) until you have fed the clutch and it has dropped into gear on the reverse/forward box!
Must say it works a treat!
Edited by blunder, 02 December 2015 - 01:17 PM.
#88 blunder
blunder
  • 120 posts
Posted 02 December 2015 - 01:08 PM
Here it is
Edited by blunder, 02 December 2015 - 01:16 PM.
#89 blunder
blunder
  • 120 posts
Posted 29 February 2016 - 12:03 PM
Not updated in a while life's been busy!
Air/Oil cooler in place of standard water/oil cooler
911C6979-5092-48A1-AB73-CE00C56F9060_zps
Tidied all the wiring and fuse box
708FFEE3-07C4-41F2-95C6-40F6DC965CB0_zps
Car has now been run up to temp and all is great so grill attached!
EA90FBBC-58D1-44EA-9031-2941799558AC_zps
Should be good to get brakes hooked up and driving very soon!
#90 jonny f
jonny f
  • 1,485 posts
Posted 01 March 2016 - 06:22 PM
Very nice.
