92 Mini City
#166
Posted 02 October 2017 - 03:34 PM
Zinc primer is on order so I’ll finish the rest this weekend
Photobucket is doing my nut in taking longer and longer to upload bugger !! ☹️
#167
Posted 08 October 2017 - 08:53 AM
Thought Id make a start on the second hub
Here it is in all its rusty glory
Stripped off both ball joints top arm and the brake shield
Thought it might be useful at this point to do a little how to on bearing removal just for anyone who hasnt removed one before
Prize out the rear seal using a long flat screwdriver
Then remove the spacer that sits under the rear seal ( these are original bearings ) some aftermarket kits wont have them
Then remove the roller bearing
Underneath you will see the centre spacing ring ( this is what usually seizes onto the shaft )
And removed
Now you can clearly see the rear bearing carrier
Flip it over and remove the front grease seal
Again remove the roller bearing from the hub wipe out the grease and you can start removing the 2 carriers
I used an old screwdriver and a drift to drive them out
Just gently in a clockwise rotation start hitting the top face of the bearing carrier until it drops out the hub
Take your time as to not damage the inner face of the hub or the bearing carrier if your going to re use them
I found the rear harder to remove as it sits in further but this is an easy job for the DIY mechanic
Once removed I just thread a piece of wire to keep them in order
Mark
Edited by Marco1972, 08 October 2017 - 09:00 AM.
#168
Posted 08 October 2017 - 10:06 AM
Attacked it with the knotted wire wheel
Wear eye protection with these as they shed wire strands as they wear
Top steering arm
This has had it
Then into the parts washer
Washed and dried them quick wipe over with panel wipe then a coat of primer and paint
I use a heat gun to warm the parts slightly this helps the paint adhere to the parts better
Gave them a coat of satin black I’ll leave them to harden for a week
With that done it was onto ball joints for the hub I did last week
Fitted to the hub
New bearings time
Just the reverse process of removal
Rear inner carrier first
Bearing fitted (no rear spacer on these) followed by the grease seal
flipped over and centre spacer fitted
The finished hub
I’m also replacing the outer CV joints these come in bear steel so I’m giving them a lick of paint
While I was painting I gave the manifold a lick of paint
The inlet came black from new so I’ve just returned it back to the factory look
The finished item
Did one of the drive flanges too
Lastly I finished off the loom
Brass connectors
Replaced the broken connector
Sorted
Tried the vinegar method on the old fuse box but wasn’t happy with the results
Think it was a bit too far gone so went for a new Lucas fuse box
That’s the loom all sorted now
Onwards and upwards
#169
Posted 08 October 2017 - 01:17 PM
#170
Posted 09 October 2017 - 03:25 PM
Looking good. Great informative post on bearing removal
Thanks buddy
#171
Posted 22 October 2017 - 04:41 PM
Both front hubs are now finished 🙂
Now if you follow this build you'll have seen me refurb my radius arms way way back they have been sat on a shelf in my shed ever since
Well I pulled them out and found that they were rusting up ☹ Not a happy bunny so Ive had to do them again
Ive bit the bullet here and got new drums ,back plates ,cylinders and a few other bits got a pal in the trade so saved a few quid 👍🏻
Out came the twisted knot on the grinder and ...... well you know how it goes 🙂
Decided to give them a few coats of lacquer hopefully this will keep the moisture out and the rust away
The new drums and back plates will get a few coats of lacquer but thats a job for next week
All the running gear apart from the top arms ( ill do them next week ) will then be refurbished and ready to go on the car when it returns
Still a long list of bits to do ( starter motor , alternator , steering colum , gear selector ) the list goes on 😃
Mark
Edited by Marco1972, 22 October 2017 - 04:52 PM.
#172
Posted 23 October 2017 - 08:36 PM
#173
Posted 25 October 2017 - 03:04 PM
Great project! At least I'm not the only one who's minis taking a while to do . Fantastic car keep up the good work !
Thanks buddy
I had no idea it would take this long either but that’s minis for ya
5 years and counting
Mark
#174
Posted 29 October 2017 - 04:41 PM
Gave the new backplates a coat of paint and lacquer
Probably going a bit OTT here but hey ho
Gave the new drums and cylinders a coat of lacquer
Then began the assembly process
With that done it was onto the gear change
Primer and paint time
Gave the aluminium body a coat of laquer to stop it corroding
Bottom plate on with stainless bolts
The finished item
Top arm time
Assembly time
Same for the other side
I smeared a bit of grease on the bearing to help it along drifted it in with a 18 mm socket on a bar
Forced new grease through the nipples before fitting
All greased up
Ive also refurbed the lower shock bolts and spacers as it is almost £20 for new ones !!
no pics as its not very exiting seeing a rusty bolt 😀
Thats all the running gear sorted next job will be the engine
Mark
#175
Posted 29 October 2017 - 06:49 PM
#176
Posted 29 October 2017 - 08:27 PM
Nothing wrong with tractor enamel.. it hasn't got cyanide in it, so doesn't kill you, it goes on really well with a brush and it smooths itself really well. Best of all it's tough like the old Hammerite
This is a fab project ... heart and soul has gone into that car...
Edited by ga2davt, 29 October 2017 - 08:29 PM.
#177
Posted 29 October 2017 - 09:53 PM
Thank you
#178
Posted 29 October 2017 - 10:08 PM
I just use regular satin black spray paint on top of a few coats of zinc primer and on certain parts clear laquer
Probably won’t last as long as the parts I’ve had powder coated but this car is going to have an easy life when it’s finished weekends and the odd mini show
Mark
#179
Posted 18 November 2017 - 12:38 AM
Next on the refurb list was the brake callipers
Refurb kitts
Used my compressor to pop out the pistons
Split the Calilper and removed the pistons
The pistons were actually in pretty good nick but you cant skimp on brakes
With the pistons removed I checked the bores which were fine and began removing the seals
Flat head to remove the retaining ring and top seal
They come out really easy
And the inner seal
With that done I wire wheeled them
Before and after
Then the usual primer and paint
Got photobombed by the cat
Went for electric blue for a change
Fitted the new seals and pistons
You have to be really careful fitting the retaining ring as they bend really easy
I cut a piece of wood and used that in the vice which worked well
Quite happy with the result
Another box from Minispares
Lots of little bits nuts bolts ect
Now Im going fairly standard with this car but I couldnt resist a bit of DSN bling
Decided to build up a few bits indoors its quite nice actually using some of the parts Ive been collecting for the last 5 years
Fitted the poly bushes to the engine steady
Grommets for the new backplates
New brake pipes and goodridge hoses
Got all the parts ready for the front subframe rebuild
New poly bushes to the lower arms and tie rods
Polly bump stops and new thick spacing washers
This little lot will be going on the front subframe in my next update
Mark
Edited by Marco1972, 18 November 2017 - 12:41 AM.
#180
Posted 18 November 2017 - 01:05 AM
My top arm stainless steel kit arrived today so it was time to start building up the front subby
Seems like ages since I had this powder coated 😀
Had to remove the powder coat from these areas due to the tight tolerance of the components found this out when we built jays car
Cones went in first ( I painted the upper ring ) as the Minispares coating was crap
With that compressed up I fitted the trumpet bit of copper grease to make sure it doesnt seize in
Now after much hassle trying to fit the trumpet in the gap after the top arm was fitted which didnt work I dropped off the top arm and fitted the trumpet to the top arm first then fitted the whole thing to the subframe this seemed to work so if anyone else is doing this particular job its worth doing it this way
Save yourself mucho hassle 😃
Didnt take that many pics as it was getting bloody cold and crawling around on a concrete garage floor isnt much fun
Anyway a couple of pics of the finished item
http://s1355.photobu...n38l.jpeg.html][/URL]
Thats it for now hopefully Ill have a car body back soon to stick this lot onto 🙂
Mark
