Posted 29 January 2013 - 04:49 PM
the arrangment in your photo of your car is the same as mine and should work fine. It will be the same as in the link you sent, if you swap 2 with 3 and 1 with 4 to get as per the linked alternative, that will do the same thing, because there are twin coils so as long as 2 and 3 are off the same coil, and likewise 1 and 4, it will work.
The rover workshop manual is wrong, unless there happened to be a version of the coil pack with that arrangment. Try it and see! I did, and may car would not run at all!
I think whats clear for you is that if you defo have no spark from leads 2 and 3, then it wont matter about the firing order - your coidl pack is faulty almost certainly. But I would check the multiplug connector and wiring to make sure clean contacts and no broken wiring from the ecu. Maybe do a continuity test just in case. becuase its possible the firing signal from the ECU is not reaching the coil that operates plugs 2 and 3.
