Mki Racer Build
Camshaft1982
, Jan 24 2013 02:44 AM
93 replies to this topic
Posted 24 January 2013 - 02:44 AM
Well ladies and gentlemen, here is what I'm starting with for my build.
She looks rather rough right now but I'm sure she will be set to go in no time.
Apart from the body work, which is quite a bit of work, I will be installing a custom cages historic chromolly roll cage, swapping out the wet suspension for a dry setup, swapping out the old 850 for a 998, lexan windows, fiberglass front end, 13" wheels and some very sticky rubber.
Posted 24 January 2013 - 02:50 AM
That is so so awesome.
Posted 24 January 2013 - 08:20 AM
Good looking project, I've got a MK2 that looks very similar to that in colour & condition. Good luck.
Posted 24 January 2013 - 10:09 AM
What year is this one? Looks like a early one with the magic wand
Edited by kappa, 24 January 2013 - 10:10 AM.
Posted 24 January 2013 - 03:10 PM
Looks good. A lot of work there!!
Although i think its quite cruel to put 13's and a flip front on that.
Stick with 10's and a full steel front. Be a lot more valuable if you ever sold it and just nicer in general.
Posted 24 January 2013 - 03:28 PM
Noice!
By the time you get around to buying wheels, we'll have persuaded you to get 10s
Posted 24 January 2013 - 03:31 PM
nice project ! 10s
Posted 24 January 2013 - 04:39 PM
Very nice! Standard steel and 10" wheels would be lovely.... glad you've changed your mind .... ; ) ; )
Posted 24 January 2013 - 06:51 PM
Nice mk1 project..................
Posted 25 January 2013 - 05:40 PM
In order to run the best tires I have to run 13" wheels so that isn't going to change. And as for the fiberglass front it came with the car so it's going to be going on too. It will just make working under the hood easier, or bonnet as you fellas would say.
The main goal for this build is to build a car that can change direction quickly, stop quickly and carry speed through the corners. The looks of this car are not important, my motto for this build,
Quick and Dirty
Quick and Dirty
Posted 25 January 2013 - 07:27 PM
If you want to change direction quickly, 13's aint a good option on a mini...
flip front don't make engine work any easier in my experience.... they just mean you have to lean over more....
Posted 25 January 2013 - 08:36 PM
I agree with the above.
10's work the best on a mini!
These real early cars are getting very rare be sad to see on 13s with a flip front. Maybe buy a later shell?
Posted 25 January 2013 - 08:59 PM
Tell that to bill Richards! He runs the KAD mini with 13's! I asked him the same question and he responded with the tyre choice answer!
I think it would look good! Split rim 13's ;) would look awsome!
Nice project by the way! Nice to see another early racer here:D
Posted 26 January 2013 - 12:17 AM
Don't forget it's a real pain to get 10" tires over here. The tires that work are only available in 13".
Posted 26 January 2013 - 08:19 AM
You can get Hoosier slicks in 10 8)
