Allways use a mask, just like having sand in your eyes or worse
Tucker
help welding please
robmeeks
, Jun 03 2004 12:15 PM
20 replies to this topic
#16
Posted 04 June 2004 - 06:52 AM
#17
Posted 04 June 2004 - 07:41 AM
Never ever try welding without a mask, Ark eye is when the bright light BURNS part of your eye. Very bad for you.
Dont bother with a big bottle unless you plan on rebuilding a car a month. If you correctly adjust the gas rate a disposable bottle will last for ages. I have in the past used them and been able to seam weld a full shell on less than one bottle.
As Doug says practice is the best. I would start on say 3 mm steel, its much easier to weld thicker metal, till you get the hang of it then try smaller stuff. Don't use old steel buy some new, 3 mm flat bar is about £3 for a 7 meter lenght.
You local panel suppiler will sell you the correct size sheet of steel for body repairs.
The main thing is to make 100% sure that whatever you are welding is clean, all the rust and dirt cleaned/ground off.
Siggy
Siggy
#18
Posted 04 June 2004 - 04:42 PM
the other usually free source of metal is your local sunroof fitting centre!
we had to put a few patches on my mates racer over the winter, went to the local sunroof place, and he was very helpful, just said take as much as you want!
#19
Posted 04 June 2004 - 06:41 PM
cheers bud
#20
Posted 04 June 2004 - 08:29 PM
I only have a cheap hand held mask and its a pain in the arse because you always have to have one hand holding the mask. If your on a tight budget at least get a head mask so you have an extra hand to support the torch if necessary.
Machine Mart sell wrap around head masks for less than £10, a small price to pay for keeping your eyes safe!
#21
Posted 04 June 2004 - 10:05 PM
i cant enforsice enough on wearing a mask, when i started welding, the trill and error method, i wa using an arc welder, lost count of teh times i was in hospital with arc eye, not worth it your site is the best thing you have!!!!!!!!!!!!
