Is there a better way of removing unwanted paint (flicks) than something like T-Cut? I think the neighbours have been painting and my mini has bore the brunt.
any help would be appreciated as t-cut is removing more of my paint than the flicks
thanks
si
Other than T-Cut
floatintoast
, Apr 10 2006 12:30 PM
9 replies to this topic
Posted 10 April 2006 - 12:30 PM
Posted 10 April 2006 - 12:55 PM
what type of paint is it? if it's emulsion then it's water based and if you use nice warm soapy water and a little pressure it'll come off no problem!
Posted 10 April 2006 - 04:28 PM
Yep, try warm soapy water first... If it's just not shifting then give it a light rub with some white spirit.
Most household paints are spirit based, but be careful and try it on an inconspicuous area first, just incase you have some weird paint on your mini that will melt with white spirit (highly unlikely though)
Good luck!
Good luck!
Posted 10 April 2006 - 04:53 PM
Acetone (nail varnish remover) will remove most uncured paints, but as above there is a risk of it taking off your good paint as well.
Autoglym tar remover or insect remover would probably work.
Posted 10 April 2006 - 04:55 PM
maybe politely ask your neighbours what sort of paint it was they used? Then you know what you're going to have to do to remove it...
Posted 12 April 2006 - 09:57 AM
By this i assume you mean the cloth you are polishing with has colour coming off on it ?
If so you should not need to worry about it, it should not rub through, you are just removing dead paint..
If nothing else this will bring a nice shine to your paint..
A couple coats of wax after the T-Cut and you should have a nice shiny protected car..
Posted 20 April 2006 - 05:20 PM
have you considered using a clay bar - that will take of surface impurities inc paint flecks. can get meguiars clay bar from halfrauds
Posted 20 April 2006 - 06:20 PM
i would definatly put my money on the clay its fantastic stuff, removed everything from ur paintwork except the paint, from halfords its only about £13
Posted 20 April 2006 - 08:01 PM
Realised where the paint has come from. I take back my unfounded accuastions on my neighbours - so quick to accuse lol.
Took the mini to a garage to replace my under sil and he painted it after but obviously didnt cover any of the paintwork, completely forgot about it, under the dirt and mud from winter must not have noticed. does this change the circumstances at all?
si
si
Posted 22 April 2006 - 06:49 AM
Yep!
Because now it's probably underseal or 2k paint......
You won't get that off with soapy water, white spirit or a clay bar.... The only thing you can do is rub it out with compound or wet and dry paper, especially as it's been there a long time- it will have properly set into the paint layer underneath now.
If I were you, I'd be inclined to take it back to the garage who forgot to mask your car up and get them to deal with it!
If they say it won't come off then they owe you a respray of the parts covered with their paint!
