Roll Cage Creek Is This Normal
joss
, Feb 15 2013 04:30 PM
13 replies to this topic
Posted 15 February 2013 - 04:30 PM
The roll cage in the rear quarters of the Mini creek when going over bumps is that normal?
Posted 15 February 2013 - 04:39 PM
If it's creaking there must be movement - not good at all......
Bob
Bob
Posted 15 February 2013 - 05:27 PM
can you pinpoint the area that is creaking? i.e the bottom bar where it bolts to the rear frame. make sure everything is tightened up. is it not the shockers?
Ed
Ed
Posted 15 February 2013 - 07:02 PM
Hi Ed the noise seems to be coming from the around the area of the torsion bar/shocks area at the top of the frame on the drivers side I will go around checking for loose bolts.
Anyway how are you
Anyway how are you
Posted 15 February 2013 - 10:51 PM
doing fine mate, plodding away with the Anglia. i've booked it in for one of our local car shows in may, so i better get the finger out and get it finished.
the Anglia is in the march edition of the retro ford magazine which has given me some motovation to get it finished
Ed
Ed
Posted 16 February 2013 - 10:14 AM
Just a thought but are you using poly bushes? They certainly creak and groan (or they did on my 911 track car).
Bob
Bob
Posted 16 February 2013 - 06:03 PM
no there all rubber bushes I at my wits end trying to work this one out
Posted 18 February 2013 - 11:21 AM
Joss try giving the metal bushes on the suspension a spray with some lube, I use GT85 to lubricate my rose joints and metal bushings on the suspension units.
Posted 18 February 2013 - 01:59 PM
Thanks for the advice
Posted 18 February 2013 - 09:25 PM
make sure its not this , its the badly triangulated suspension mount at the back top shocker mount. mine made all the same noises until this. couldn't tell it was cracking under the power coating. joy. complain to zcars if the noise persists if the rose joints are not at fault.
alreidy.dyndns.org/ouch/IMG_0619.JPG
Posted 20 February 2013 - 12:57 PM
Al, you did have the worst luck with that car.....:-(
Posted 20 February 2013 - 01:01 PM
yeah well its over with now. lost £13,000 with it.... live and learn.
Posted 26 February 2013 - 06:26 PM
Thank you for that i will check it I hope its just the rose joints singing out sorry about the car heart breaking when you put so much in to project and it goes tits up like mine last week
Posted 27 February 2013 - 08:26 AM
hOLY Sh!T - What happened?
Ignore - just seen post about black ice....
Edited by cptkirk, 27 February 2013 - 09:05 AM.
