Just Another Pick Up
Rosslin Racing
, Feb 24 2013 10:44 AM
106 replies to this topic
#61
Posted 11 March 2013 - 01:33 PM
It looks like its had m machine half floors put in at some point!
#62
Posted 11 March 2013 - 03:24 PM
Pickupmad87, yes was haidran and not done well, so it had to go! saying that I cut it so that it can be cleaned up and used agian on someones project its not a pick up/van floor but estate.
#63
Posted 12 March 2013 - 04:01 PM
this is one of the things that can kill a project waiting for panels
#64
Posted 12 March 2013 - 07:12 PM
well at least I know it should not be later that thursday.
#65
Posted 12 March 2013 - 09:05 PM
Nice work!
Keep it going!
Keep it going!
#66
Posted 17 March 2013 - 01:41 PM
Day 7
now that the reinforcing plates are welded it its time to sort out the back end of the load bay.
The lip must be wrong This is what i thought, maybe I have welded the lip in the wrong way but that would not answer the fact nothing lines up.
It all looks wrong! why have i got a step in on the edge of the load bay? took a while to realise that the answer was in front of me the whole time
on the yellow panel you can see a bent in the panel thats what the step replicates. so its the flats on the step that lines up and not the faces.
abit of trimming was done and it looks like it all fits now:
#67
Posted 17 March 2013 - 04:39 PM
looking good! have the rest of your panels arrived!!
#68
Posted 17 March 2013 - 05:54 PM
Pickupmad87 did you not have the same problem? and yes only one panel missing now.
the toe board
the toe board
#69
Posted 17 March 2013 - 06:45 PM
yes i did but was all sorted. havent done much the last week and this weekend! had to walk away from it! manged to do a bit today tho.
#70
Posted 23 March 2013 - 10:25 AM
Any of my Pickup mates out there Know if the rear bulkhead should be flat or have a curve it in?
#71
Posted 23 March 2013 - 02:23 PM
The pickup load bay bulk head should have a 'joggle' in it , so the drivers side has a more leg room in the cab
Not totally sure this is what you are asking ?
#72
Posted 24 March 2013 - 11:53 AM
sorry from top to bottom as it were, should that have a curve in it?
#73
Posted 25 March 2013 - 06:21 PM
Yes there should be joggles in it for strength. And as said the drivers side should be further back than the passenger side. So a curve in the middle from the top to the bottom edge. Can get a PIC tonight if you want
#74
Posted 25 March 2013 - 06:56 PM
ok forget the joggled bit forget the curve for the driver, whats left? my Panel has a bow or bend or curve in it, you can see it best by looking down on it from the window so it runs in the same direction as the joggled elements.
its not so visible on the photos but it a good 1.5cm in total!
Edited by Rosslin Racing, 25 March 2013 - 06:58 PM.
#75
Posted 28 March 2013 - 05:15 PM
