Just Another Pick Up
#76
Posted 28 March 2013 - 05:18 PM
#77
Posted 28 March 2013 - 06:15 PM
#78
Posted 28 March 2013 - 07:00 PM
#79
Posted 28 March 2013 - 11:05 PM
#80
Posted 11 June 2013 - 01:24 PM
time to get back on with this, got sidelined with work and stuff.
#81
Posted 11 June 2013 - 02:27 PM
I no that feeling looking forward to some piccys though matey.
#82
Posted 11 June 2013 - 06:20 PM
I have maked out the rear bulkhead and made some repair panels .
#83
Posted 12 June 2013 - 02:15 PM
wondered what happened to this as you was making loads of progress over a short time, good to hear its still going
#84
Posted 12 June 2013 - 05:37 PM
#85
Posted 13 June 2013 - 06:55 AM
well done on saving the shell, theres some work needed on it but it looks like you're doing an awesome job so far
#86
Posted 13 June 2013 - 10:55 AM
Thanks for the words of support and encouragment, time to get on and do loads of photos.
#87
Posted 13 June 2013 - 12:12 PM
#88
Posted 22 June 2013 - 07:49 PM
well abit of progress has taken place, repaired the rear panel, banged out bumps and cut out rust and replaced with metal. the cab has now rejointed the floor pan and has had a new step on the drivers side. still a lot to do before I can move on to the front inner wings. photos to follow
#89
Posted 22 June 2013 - 11:26 PM
Dan
#90
Posted 30 August 2013 - 09:49 AM
Up date I have now fitted the door sills and found that the LH side magnum door sill is longer than the RH side! measured both sides and the holes are the same size all round, so i used an M-machine panel and it fits like a glove the magnum was 1 cm to long!
Cut out the toe board and welded the Heritage panel in that was fun . Now the cab is fitted I started on the outer a panels and have welded them in flush. Got fed up with the front so I have moved to the back end in order to fit the boot hinge mounts next problem, it seems as if the slot from the lower lip are too low so I am going to have to cut and shut that.
