Edited by Rosslin Racing, 28 August 2016 - 06:39 PM.
Posted 05 September 2013 - 07:52 PM
the rear corners are turning out to be a real sod to do!! photos to follow. I have to cut the corner panels around to get it to fit like it should
Posted 05 September 2013 - 08:04 PM
Posted 01 May 2015 - 09:19 AM
small up date on this, I have been working on this car when i was back from college at easter,
I finally got the rear hinges and related panels welded on, the rear lid fits and the corner are going to fit once I am back they need a fettle. roll on june.
Posted 02 May 2015 - 06:48 AM
Hope you manage to get back on it soon looks like its taking shape :)
Posted 28 August 2016 - 06:53 PM
OK so its been a while!!.
cut things short DAY 8,9,10,11 and 12 have been measuring fitting, trimming removing streaching and shrinking of panels. A large amount of head scratching and Tea. the result is the back end is almost ready to weld on.
The drain holes proved to be fun in the end I found some electric ducting with a 0.08mm wall thickness. to create the round edges I used an old steering arm which has a hardened ball on the end. I place a tube under the floor and match the floor and tube together.
Edited by Rosslin Racing, 09 September 2016 - 11:35 AM.
Posted 20 November 2016 - 07:28 PM
so after replacing the magnum step with an M-Machine the door now fits the sill line. the O/S is now with sill and rear panel all welded and glued. the N/S all fits but I have not welded rear panel or sill on as I have the feeling I am going to be moving panels around.
I have removed the from screen frame and scuttle so the I can start the roof correction.
Posted 22 November 2016 - 04:19 PM
the silver bits are the stretched metal or high spots, caused by some muppet trying to hammer out dents or (dints as steve would say) from inside with a ballpain hammer. it will have to be shrunk using heat lots of shrinking in fact. I have already started, photos to follow, and some of the big divets have popped back out. this due to the tension in the panel. happy days.
Posted 24 November 2016 - 11:24 AM
Posted 27 November 2016 - 09:23 AM
Feel a bit sea sick looking at that roof
yes know what you mean. its the only option is repair. New ones do not grow on trees, saying that I do have a new old stock roof skin but I also have a second pickup.
Posted 27 November 2016 - 01:20 PM
I've no doubt it will be spot on with the workmanship you knock out I look forward to your updates,were those magnum rear quarters and what did they fit likeyes know what you mean. its the only option is repair. New ones do not grow on trees, saying that I do have a new old stock roof skin but I also have a second pickup.Feel a bit sea sick looking at that roof
Edited by Van13, 05 December 2016 - 12:46 PM.
Posted 20 December 2016 - 02:27 AM
Posted 25 December 2016 - 11:27 AM
Yes they are Magnum, they need trimming and some loving to get them to fit nice.
Posted 02 January 2018 - 06:32 PM
Edited by Spoonz, 02 January 2018 - 06:33 PM.
