any one know of anywhere to get powder coating done in the westcountry preferably in the taunton bridgwater area.
also any idea of costs i want both subframes and rollcage done white, radius arms, tie rods and all other suspension bits done light blue
thanks jamie
powder coating in south west
bousfield19
, Apr 14 2006 11:08 PM
4 replies to this topic
Posted 14 April 2006 - 11:08 PM
Posted 14 April 2006 - 11:23 PM
Don't get any external bits done in powdercoat, it's nasty. It flakes in huge chunks, it can't be repaired or touched up, it's not remotely stone chip resistant. Once you get a little chip, a huge lump peels off. Loads of my gear at work is done in powder coat and most of it has to get stripped and re-coated once a year when it gets inspected as you can't inspect through powdercoat and it hides defects. I don't like it as you may be able to tell. Get it all two-packed, cheaper, better range of colours, longer lasting and tougher.
Technically I've been told it could be an MOT fail as well as you can't tell how bad corrosion is under powdercoat.
Posted 15 April 2006 - 12:01 AM
What if you laquered the powder coat? How much would the above cost to two pack rather than powder coat?
Posted 15 April 2006 - 12:09 AM
thanx for the quick reply what do u reckon it will cost then for it all done and where will it be best to get it done then?
will any spray shop be able to do this ?
Posted 15 April 2006 - 04:39 PM
there is a place in bristol that does this, just got my bike frame done, that cost £40 so your looking around £100 for all your bits, go to a spray shop and ask them hw much they want, i think it'll be cheaper to get them painted ( and better wearing and shinier) than getting them coated. i'll dig out the number for the powder coaters but i would go for paint any day on those bits!
