Low Boost Daily Drive
Posted 16 March 2013 - 05:20 PM
Hi i am new to the turbo side , Just wondering what spec i need for a daily drive simple turbo set up with a bhp around 90-100bhp , would this be ok for a daily drive set up wit a low boost looking for a similar spec to metro turbo . I have a mg metro engine at the moment which needs a rebuild i have a set of 21262 pistons which are unsed will these be ok if i dont need a rebore for a higher mileage turbo or would a set of 21253 be better. Could someone suggest a set of pistons and what sort of mileage people are getting out of there .
Posted 16 March 2013 - 07:13 PM
100-120 hp should be nice and reliable, basically go for std metro turbo spec, but with a better head and a decent intercooler. 10 psi should get you where you want to be.
Oh and fit a 4 pin diff!
Posted 16 March 2013 - 07:18 PM
Posted 16 March 2013 - 08:57 PM
a well set up turbo is capable of returning 40mpg+ on the motorway at around 60mph,
Posted 17 March 2013 - 04:01 PM
Posted 17 March 2013 - 04:21 PM
t2 turbos are tiny therefore your almost constantly on boost
the whole low boost low power thing will go out of the window when you start driving it lol
http://www.turbo-mini.com/62147.html -> WIL H's 20hr 998 turbo conversion
is what you want to read
read it, then read it again, have a look through the website
and then anymore questions he is on this forum and turbominis.co.uk
Posted 17 March 2013 - 07:33 PM
Posted 17 March 2013 - 07:37 PM
i like to be kicked in the chest, the real feeling of "coming on boost"
the t2 is perfect for a 998
yeah mileage shouldnt be a problem, around 40+mpg depending on how you drive it
are you bolting it on a used engine?
those 998's go on for everrr if they have been looked after, would advise
new headgasket, 12g940 head, new water pump and oil pump and oil change and should be a reliable good engine
Posted 17 March 2013 - 08:17 PM
Posted 17 March 2013 - 08:50 PM
Turbos need to be low compression due to the turbo pressure
Can get away with it though depending on piston cc's and abit of head work
I'd change the head gasket on the 998 and all the other bits and run it till you get bored/ while rebuilding a powerful 1293 turbo motor
You can use the head off it for the 998 for now
Posted 17 March 2013 - 09:51 PM
It going to be a daily drive doing 8k a year or so. And I will be using 21253 pistons are they ok for the cc dish to get the compression
Posted 19 March 2013 - 07:20 PM
dpends what compression ratio you want.
Posted 19 March 2013 - 09:10 PM
Ie. boost
Should be ok for 7-10psi
Which will get you to the power you want but worth double checking
Posted 21 April 2013 - 11:33 AM
Posted 23 April 2013 - 01:27 PM
think it ran the 21251 in it just fine
