Air Conditioning Compressor Vtec
2 replies to this topic
#1 mowog4
mowog4
  • 19 posts
Posted 17 March 2013 - 04:12 PM
Is there anyway to run an AC compressor in the Vtec kit. Does not appear to be enough clearance for it. Also, does anyone have any tips on installing the vtec into the frame? I am guessing some of the suspension needs to be removed.
Thanks,
Ed
#2 cptkirk
cptkirk
  • 1,799 posts
  • Local Club: B.M.C. + Chiminiclub
Posted 18 March 2013 - 09:20 AM
Ed
You are correct in that there is not room for the AC compressor in its original position, if you really want it you would have to come up with a new bracket and reposition it.
Re getting the VTEC engine in/out- ideally you need to remove the two rear trailing arms and the rear coil-overs, this will give you good clear access to drop the engine onto something. Be sure to note what amount of washers came from where when removing the trailing arms and there shouldn't be any need to fiddle with the camber adjuster on the inside fixing. You will need to remove the rear calipers from the trailing arms if you have them plumbed in already.
#3 ZCars Steve
ZCars Steve
    Z Cars
  • 141 posts
Posted 22 March 2013 - 02:48 PM
you should be able to fit the rear frame without removing the rear arms if you have the rear valance removed if its a race frame you will need to fit the front subframe and with the help of a few friends lift the back end up high and slide the frame inside as you lower it back down (i know its not a mini but its the same principal)
Attached File  DSCN1969.JPG   68.44K   16 downloads
