Anyone Fitted A Series Spares C/l Kit On An Mpi?
Posted 26 March 2013 - 01:03 PM
I've left a message and emailed A Series Spares but no response yet. Anyone successfully managed this?
Posted 26 March 2013 - 02:05 PM
Posted 26 March 2013 - 02:30 PM
Posted 24 January 2015 - 02:14 PM
Did you ever fix this..? have been looking at the A-series kit for my car. Does it work with the Rover Fob?
Q
Posted 24 January 2015 - 02:44 PM
Never fitted the A-series kit, but I can recommend the one by mini spares (MSSK2004). I fitted this to my MPi several years ago and it worked brilliantly - I didn't have any problems with the impact bars getting in the way.
The Rover alarm is the same as they fitted to all other Rovers at the time, so already has outputs to drive a central locking mechanism. If you buy the extra conversion kit (MSSK2006), the mini spares one works remotely off the Rover key fob.
Posted 24 January 2015 - 10:29 PM
sweet
How do the wires go from the body to the door...? I assume just under the door catch? Is the tube from car to door weatherproof?
Posted 25 January 2015 - 10:35 PM
sweet
You have to drill a new hole in the door between the hinges and a corresponding one to thread the cable under the dash. The kit I had then came with a rubber grommet to protect the door, and the cable was pretty well insulated. I may have put some extra tape on mine just to be on the safe side, but I never had a problem with the electrics (it's been in for over 7 years now). I was always concerned that the mechanism was quite delicate, but it's survived the vibration of thousands of miles without a hitch.
Posted 15 January 2018 - 01:02 AM
Hey Tom, How did you get on with fitting this central locking kit to your MPI? I'm planning to buy a kit from A-Series Spares soon for my MPI.
Posted 05 February 2018 - 11:03 PM
I chose the second option and It is functional, for a show car i would take the doors off.
Posted 15 September 2018 - 09:56 AM
J-gerbes I’ve got central locking and it’s all pretty easy apart from drilling the hole from the door to the door surround to run the wiring, either take the doors off or use the drill at a dangerous angle and say a few prayers
Thanks for this advice. I ended up taking the doors off as I didn’t trust myself enough to drill it with them on.
I’m having a similar issue with mounting the small bracket that goes onto the locking mechanism as the side impact bar is in the way. Two wire pieces were also provided with the kit, I imagine these may be for the MPI? Any advice would be very much appreciated
Posted 06 October 2019 - 09:08 AM
Did either of you chaps get an answer to the MPi door problem? I did order the A-Series kit, but never received it and know with them having gone under, there is no one to call if I manage to get a second hand kit and have issues.
Posted 25 June 2021 - 12:31 PM
A long time ago now, but *bump*
