Anyone please help......I have purchased the zcars mini loom and also busa to mini loom and in reading the instructions which are classed as "easy" im finding it very confusing. If there is anyone in the Aberdeen area that has done one or is willing to help im all ears as i cant afford what i was quoted by zcars.
Any help or pics would be VERY helpfull
Alan
Wiring My Busa Clubman?
plugfaebervie
, Apr 11 2013 09:15 PM
4 replies to this topic
Posted 11 April 2013 - 09:15 PM
Posted 12 April 2013 - 07:19 AM
I have spoken about this before and I believe they are changing things in the future but the instruction sent out with the wiring loom are not 'easy' by any means. I can only tell what I did and hope that it might be of some help (although mine is a vtec conversion), sit with the instructions, a pen, some masking tape and the loom and go through every connection and its seperate wires, labelling each wire as you go, this will familiarize you with the loom and hopefully it'll make a bit more sense afterwards. Note that a lot of the connectors will need to be swapped out for better and some wont have any connectors so once you know whats going where you can begin ordering connectors, some will need to be waterproof. Consider the ampage when ordering connectors. as for mating the two looms I am afraid that I cant help there, just relaying my experience of wiring.....good luck.
Posted 12 April 2013 - 11:04 PM
Yeah that sounds like a plan gonna make a start tomorrow on tagging all the wires, but i got a plug delivered the other day from zcars with instructions like connect green wire to yellow wire on mini loom fair enough but theres 4 green wires what the hell!!! pardon my french. ive phoned auto electricians and no one will look at it
on the plus side ive found a place to make my rear bulkhead using templates ill make tomorrow aswell
Posted 28 April 2013 - 04:42 PM
How have you got on with your wireing ?
Posted 10 May 2013 - 09:22 AM
Wiring ok i think and hope the reason was i had the car wiring instructions so i was a bit confused but all seems good now just waiting for a starter solenoid to get her fired up ![]()
