Supercharging ?
38 replies to this topic
#16 Grahamxx
Grahamxx
  • 188 posts
Posted 24 April 2013 - 04:31 PM
Still awating the info from VMAX resent the email this afternoon
What questions are you asking??? I made my own kit, can I help??
#17 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 April 2013 - 05:39 PM
I was going to use there install guide a write a step by step guide for the forum, there are several here keem to see something of that sort, if you can help then brilliant stuff
#18 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 24 April 2013 - 06:58 PM
Lot's of info over on TurboMinis, just don't mention your dizzy plug.........
Dizzy Plug? only ones that have a plug are the O.E Electronic ones :genius:
#19 Nick Warwick
Nick Warwick
  • 1,588 posts
Posted 25 April 2013 - 07:57 AM
I think i have a fair few photos that pretty much explain the install
#20 mailman
mailman
  • 222 posts
Posted 25 April 2013 - 08:55 AM
A 'How To' with pics would be even better!
#21 KernowCooper
KernowCooper
    Sparkie
  • Mini Docs
  • 7,847 posts
  • Name: Dave
Posted 25 April 2013 - 01:00 PM
still waiting for some info will ring again today and this will be the last!
Edited by KernowCooper, 25 April 2013 - 01:01 PM.
#22 pauly_denham
pauly_denham
  • Just Joined
  • 49 posts
Posted 25 April 2013 - 10:25 PM
I will be doing a VMAX build in the end of may so will take full photos of step by step building and post a build thread. My engine is out of the car though so might be slightly different but i will try to make the build as though the engine was in the car. But obviously you would have to wait until may/june time for me to do that!
#23 pauly_denham
pauly_denham
  • Just Joined
  • 49 posts
Posted 25 April 2013 - 11:08 PM
#24 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 April 2013 - 01:45 PM
I was down at Vmax on the 24th picking up my car following custome fuel injection mapping on my s/c 1293 vmax built. He is well busy right now! I suppose lots of cars now are being taken out of hibernation for shows etc, and upgrades etc.
Can confirm my s/c seems to produce even more power now after being used for 1000+ plus miles in the suck through way, now with injectors putting fuel right onto the rotors.
#25 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
  • Local Club: Loan wolf
Posted 29 April 2013 - 03:10 PM
Anyone seen the vmx water cooled inlet manifold. Im keen to see a pic
#26 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 29 April 2013 - 07:13 PM
I have one on my setup. Its the one on the underside of the inlet, pumped around with a small pump/resevoir and a heat exchanger with fan mounted up front. Works really well, after getting back and opening the bonnet the supercharger is much cooler, can keep your hand on it, its hot, but not roasting as it was before.
#27 uksnowman
uksnowman
  • 35 posts
  • Local Club: mini maniac alpin
Posted 29 April 2013 - 08:40 PM
I have one on mine fitted by vmax. It works great but had to re route the pipes away from the manifold it just looked a little sloppy. Will post some photos at the weekend for you
#28 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 30 April 2013 - 05:13 AM
I found the pipes kinked easily if they were routed too short, had to leave quite a loop on them to maintain good flow. Exhaust manifold is heat wrapped but I think one of the water pipes does sit very close to the exhaust.
#29 HUBBA.HUBBA
HUBBA.HUBBA
  • 2,823 posts
Posted 30 April 2013 - 08:25 AM
Pics would be great
#30 BronkoMini
BronkoMini
  • 1,485 posts
  • Local Club: Mini Fixers
Posted 17 May 2013 - 08:28 PM
Bump
