1968 998 Cooper Engine
Posted 22 April 2013 - 07:32 PM
The spec I was thinking of would be a
12g940 head
Pocketed block ^
276 cam
Lightened flywheel
Mainiflow exhaust system
Twin 1.25 carbs with sub stacs
Can anyone give me and idea on the bhp I will be getting and any other things I should consider doing I would hope to get about 70-75 bhp
Will have pictures soon
Posted 22 April 2013 - 07:38 PM
Posted 22 April 2013 - 07:43 PM
Edited by minimk1, 22 April 2013 - 07:46 PM.
Posted 22 April 2013 - 07:50 PM
Posted 22 April 2013 - 08:42 PM
I would think a 266 would be about ideal, unless it is a serious competition car.
You can overbore it to +0.080" which gives 1060 cc.
Maybe consider a 12G295 head which avoids having to pocket the block.
Make sure you set the compression ratio to around 10.3:1.
Build the engine very accurately.
Posted 22 April 2013 - 09:03 PM
Posted 22 April 2013 - 09:20 PM
Posted 22 April 2013 - 10:10 PM
Posted 22 April 2013 - 10:12 PM
Posted 22 April 2013 - 10:13 PM
Posted 22 April 2013 - 10:53 PM
Posted 22 April 2013 - 11:50 PM
I want to keep it a 998 just want it revy and quite camy on idle but with usable power
i have 998 with flat top pistons, 266 cam and 12g295 head with bigger inlet vlaves
It is good low down as it happily sits at 30 in 4th (3.44 fd), but it is still pulling hard up to 6 - 6.5k rpm
I think it would be a better spec than yours for a road car as it works well all round
i have a single hs4 but with twin hs2's like you plan to use i would imagine a small increase in power of the hs4
you say you want 70-75bhp from a 998 but i would imagine that to get this kind of power you will be losing a lot of low down pull
i hope this is helpful
Jonny
Posted 23 April 2013 - 06:37 AM
Posted 23 April 2013 - 08:59 AM
If yours are in resueable condition and the bores are good enough, I'd re-ring the pistons, hone the block and go from there - this would allow the use of an unskimmed 12G295.
As the std Cooper angine gave 55bhp, a cam change for something like an MG Metro (KC500), an SW5 or a Piper 255 would make a very nice engine that didn't need a million revs.
I'm not convinced that a 12G940 shows any advantage of a 295 at normal speeds and revs.
Posted 23 April 2013 - 06:05 PM
