Amethyst In And Running
Posted 08 May 2013 - 09:04 PM
Posted 09 May 2013 - 01:59 PM
easy to set it up?
Posted 10 May 2013 - 07:41 AM
Posted 15 May 2013 - 07:34 AM
Sounds good mate, how long did it take to install?
Posted 15 May 2013 - 08:36 PM
Posted 15 May 2013 - 08:52 PM
I think my ride height may be a bit low as they had problems getting on the ramps
I also think the amethyst has cured suspected detination, as my engine just does not over heat any more.
Rev limiter set at 5000 rpm at the moment and it works!
You can have multiple maps on the software and 2 usable one whilst driving so I am going to have a switch or button for 'sport mode' and 'safe mode' or you can set it as an immobiliser.
Very impressive
Posted 15 May 2013 - 08:54 PM
Posted 17 May 2013 - 11:48 AM
Posted 17 May 2013 - 03:01 PM
I Just plotted a 'safe' map to start with 500 rpm 8 degrees and then increments of about 2 degrees until i got to 22 degrees. Will book it in at aldon rr to finly tune after run engine in ( new engine rebuild). Probably need new needle profile as its idling at 1500rpm at moment.
Ive got the boost one, so i've plumbed it in spurring off my boost gauge pipe, but have not put any degrees advance on the air pressure yet, i was going to do that on the rolling road as well.
Edited by HUBBA.HUBBA, 17 May 2013 - 03:02 PM.
Posted 17 May 2013 - 03:05 PM
Had it running with just the ingnitor in and started really easily, but still got hot.
Wiith the amethyst in, engine doesn't over heat. But it will be interesting if it gets hotter when the advance is increased when run in.
Posted 19 May 2013 - 10:28 AM
Is it for carbed engines?
Posted 19 May 2013 - 05:10 PM
Posted 20 May 2013 - 08:31 PM
Have you got any photos of where you mounted the box as I'm thinking of going down this route but not sure where it can be mounted.
Posted 21 May 2013 - 06:39 PM
What's the difference with the mega jolt?
Posted 21 May 2013 - 08:21 PM
Made a works style dash for the left hand side and mounted it on there next to a afr gauge. Will get a pic up as soon as poss
