Head Gasket Problem
Best Answer lrostoke , 10 May 2013 - 12:46 PM
your supposed to do that after the first heat cycle anyway.
Get engine upto temp after fitting, allow it to cool down.
Then retorque head..back each nut off a touch then retorque..in correct order Go to the full post
7 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 10 May 2013 - 10:35 AM
Hi i have replaced my head gasket when i ran up the engine there is small amounts of water bubbling
from  between the gasket and the block
i have changed a few in the passed and this has never happened i have the gasket the correct way
up and done the head to 68n
could someone give advise
cherrs
Dave
#2 Vipernoir
Vipernoir
  • 782 posts
  • Local Club: Minis Unlimited
Posted 10 May 2013 - 10:39 AM
Have you calibrated your torque wrench recently ?
Most read a little light.
Undo and retorque the nuts one at a time in the correct order but do them up to 50 lb/ft.
#3 pickuptruck1994
pickuptruck1994
  • 366 posts
  • Local Club: Weston Mini Muckers
Posted 10 May 2013 - 10:40 AM
did you check that the head wasnt warped before replacing it
#4 087dave
087dave
  • 952 posts
Posted 10 May 2013 - 10:42 AM
No i have nt its a bit old alright, is it safe to undo and retorque with the system full of water
#5 lrostoke
lrostoke
  • 6,923 posts
Posted 10 May 2013 - 12:32 PM
we've had this a few times copper gaskets always did it on us even with a head skim..
We use the composite ones now...
Normally it goes after a while
#6 087dave
087dave
  • 952 posts
Posted 10 May 2013 - 12:36 PM
Would you loosing off one head nut at a time and then re torque?? in the correct order
#7 lrostoke
lrostoke
  • 6,923 posts
Posted 10 May 2013 - 12:46 PM   Best Answer
#8 jaydee
jaydee
  • 8,565 posts
Posted 10 May 2013 - 05:55 PM
Copper cylinder heads are doing this. Rover issued a note to fit them 'wet' (clean them with oil) at a certain point..
Start up the engine and warm it up just a little bit before filling up with water.
Remember to cool down the engine before re-torqueing or you'll end up with a snapped stud (not that they dont snap even when doing correctly..)
