Mixture Question
11 replies to this topic
#1 herdy
herdy
  • 377 posts
  • Local Club: Notts about minis
Posted 15 May 2013 - 09:43 AM
Is 2 and a half turns in relation to the mixture screw a lot. Only reason i ask is because a few months back my dad adjusted my mixture 2 and a half turns and it now drinks fuel like its going out of fashion. It's not been pulled up on it's MOT but i'm just curious because it's costing me no end in fuel. It's a '92 mayfair 1275 running a HIF38.
Thanks, Ben.
#2 TehMarchant
TehMarchant
  • 628 posts
Posted 15 May 2013 - 10:02 AM
Have you Popped your plugs out yet for a look?
Is the inside of the pipe deep black maybe wet?
Is their a strong smell of unburnt petrol?
#3 herdy
herdy
  • 377 posts
Posted 15 May 2013 - 10:21 AM
no, there's no smell of unburnt fuel, i've not checked the plugs. which pipe do you mean? the one going to the carb or the over flow?
#4 IainNeon91
IainNeon91
  • 1,287 posts
Posted 15 May 2013 - 10:23 AM
You should really run a HIF44 on the 1275 to get the most performance, but that's up to you...
Regarding your question, what was the reason he changed the mixture? Did you add a 'stage 1' kit to your mini?
If this is the case then you will see you will use a bit more fuel than normal, it's only until you get it properly calibrated on a rolling road that you will have the power and using a correct amount of fuel.
If this isn't the case, check your fuel lines for leaks.
Iain
#5 herdy
herdy
  • 377 posts
Posted 15 May 2013 - 10:34 AM
I'm intending on putting a HIF44 on it but at the moment the engine is completely standard. I've got no idea why he did it. is 2 and a half turns a lot then?
#6 TehMarchant
TehMarchant
  • 628 posts
Posted 15 May 2013 - 10:35 AM
I ment the exhaust, but Neon has the right Idea, you should get her on a rolling road to her sorted properly.
#7 IainNeon91
IainNeon91
  • 1,287 posts
Posted 15 May 2013 - 10:40 AM
On my HIF38 an 1/8th of a turn made a difference once i had reached the 'sweet spot' any further than this point, you could see less MPG, not a dramatic amount though.
There isn't any fuel coming out around the bottom seal of the carb is there?
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 May 2013 - 11:59 AM
2 1/2 turns is loads.  There is a total range of 1 turn where the mixture is roughly right and the car will idle nicely, and the normal level of tune would be 1/3 of the way through that range from the lean end.
#9 herdy
herdy
  • 377 posts
Posted 15 May 2013 - 12:09 PM
jesus, i dread to think how much fuel i've wasted if that's the case. i wonder what i'm doing tonight. for what its worth, the mini has been a lot more eager to go since :P
#10 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 15 May 2013 - 12:10 PM
  Just because it needed a lot of adjustment doesn't mean it isn't right though, it may have been drastically wrong before.
#11 herdy
herdy
  • 377 posts
Posted 15 May 2013 - 12:14 PM
i had a gasket between the carb and the manifold fail so that's the reason for me taking the carb off and what not.
#12 Ethel
  • 26,582 posts
Posted 15 May 2013 - 01:34 PM
You'll find info online on setting up SU's. look for "University Motors", an American MG specialist, on Youtube. You need the ignition set up properly first, and the engine warmed up.
