Problem Tuning
9 replies to this topic
#1 087dave
087dave
  • 952 posts
Posted 15 May 2013 - 08:46 PM
Hi all
i am currently trying to tune my engine that has a stage i kit stage 2 head and a AAU needle
when i use the colour tune i only get a light blue colour but the carb adjusting nut
is turned up right to the last(tighten up and opeded about 1/4 of a turn when i use the lifting pin
the carb doesnt die off, i took off the dash pot the adjusting nut is level with the bridge
and the body off the carb has petrol in it.....
Can anyone give advise
cherrs
#2 jaydee
jaydee
  • 8,565 posts
Posted 15 May 2013 - 08:51 PM
You need to lower the jet by turning the nut clockwise
See if you can get a turquoise colour or blu with some sparklin red flames every now and then.
Remember you're just setting up idle mixture and not tuning your car, you need to put load on the engine to tune it
#3 087dave
087dave
  • 952 posts
Posted 15 May 2013 - 08:59 PM
When i lower the jet the car blows black smoke and dies off....
#4 jaydee
jaydee
  • 8,565 posts
Posted 15 May 2013 - 09:01 PM
Aew thats not good, is the needle valve in the float chamber sticking?
#5 087dave
087dave
  • 952 posts
Posted 15 May 2013 - 09:07 PM
Dont think so i put a new float needle in will check tomorrow, tks do you know what the timing should be at
#6 jaydee
jaydee
  • 8,565 posts
Posted 15 May 2013 - 09:09 PM
998 or 1275?
Static timing or you're using a timing gun?
#7 087dave
087dave
  • 952 posts
Posted 15 May 2013 - 09:11 PM
998 auto with static timing
#8 jaydee
jaydee
  • 8,565 posts
Posted 15 May 2013 - 09:13 PM
Try 6-8 deg BTDC
#9 087dave
087dave
  • 952 posts
Posted 15 May 2013 - 09:22 PM
Tks how best to check static timing
#10 087dave
087dave
  • 952 posts
Posted 17 May 2013 - 05:29 PM
Thanks for the replys, it turns out it was the float valve, so i got out the colourtune and the
gas tester
i now have a blue flame and the co % is at 2.5 all good
but how can i tell that all is good when its under load , i know by looking
at the plugs and the smoke coming out of the exhaust pipe
when it is underload the plugs are yellow in colour like there is a weak mixture... so do i leave fuel fuel in....
Can anyone give any hints
