Urgent Help Needed!
13 replies to this topic
#1 bobbym18
bobbym18
  • 198 posts
Posted 16 May 2013 - 04:04 PM
Hi everyone,
My mini keeps misfiring randomly making it un-drivable. At first it was after driving for a while but no just idling its loosing power everyone now and then. I've looked at the spark plugs and they seem alright. HT leads look alright and everything in the dizzy cap looks alright.
The rocker cover gasket needs replacing but would that make any difference?
The car was only MOT'd and services 2 weeks ago. I need it for work etc so I need to get it sorted ASAP!
Any help appreciated!
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 May 2013 - 04:26 PM
best take it back to who serviced it and get them to have another go , they might of turned the fueling down to get it through the emissions test
sounds like they didn't do a very good job the first time
Edited by Bungle, 16 May 2013 - 04:27 PM.
#3 bobbym18
bobbym18
  • 198 posts
Posted 16 May 2013 - 04:34 PM
So you think it might be the fueling? Should I make it slightly richer?
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 16 May 2013 - 04:35 PM
i would take the car back , you don't pay someone to make the car worse
#5 bobbym18
bobbym18
  • 198 posts
Posted 16 May 2013 - 04:37 PM
I haven't got a day off until next weekend that's the only problem so if I can sort it myself I would like to. Before the mot and service it had been off the road for over a year
#6 Tamworthbay
Tamworthbay
  • 7,025 posts
  • Name: Clive
  • Local Club: A5 minis
Posted 16 May 2013 - 04:54 PM
It could be a lot of things, but if you have a spare condensor its worth sticking it on. It will only take 5 minutes. A failing condensor usually starts showing itself by misfires under load then gets progressively worse.
#7 bobbym18
bobbym18
  • 198 posts
Posted 16 May 2013 - 04:58 PM
Ok il try that later, I've got an old one that I replaced though it didn't really need replacing
#8 minimuk
minimuk
  • 1,947 posts
Posted 16 May 2013 - 05:55 PM
dizzy isseue, check for moisture in dizzy, I second the condenser, preferably a new one, check points gap, then check yr timing wiv strobe, then the fueling,good luck
#9 johnyc
johnyc
  • 162 posts
Posted 16 May 2013 - 07:37 PM
Timing checked? timing being off can cause epic backfires :D
#10 Carlos W
Carlos W
  • 10,115 posts
Posted 16 May 2013 - 07:42 PM
Vacuum pipe to dizzy come off?
#11 sledgehammer
sledgehammer
  • 3,129 posts
Posted 16 May 2013 - 07:53 PM
I would go with condenser - a brand new one can fail within hours - & an old one can last years
check little earth lead in dizzi (if it has one) - they can corrode
& a tiny dab of grease on the points heel - without it - can cause the points heel to wear quickly - closing them
also check with a dwell meter (if you or a friend has one)
another thing - fuel may be a bit stale if it's been stored a while ?
but also contact the garage that serviced it
Edited by sledgehammer, 16 May 2013 - 07:56 PM.
#12 bobbym18
bobbym18
  • 198 posts
Posted 16 May 2013 - 08:19 PM
Seems to be sorted for now. It's been misfiring all day while the engine was idling. I tried everything then I just sprayed WD40 on the dizzy cap, inside and out and it seems to have stopped for now.
Going to get some new leads tomorrow and see how she goes :)
#13 tiger99
tiger99
  • 8,584 posts
Posted 16 May 2013 - 08:40 PM
The trash condensers on the market these days may indeed fail within days. Even when they were properly made, and not in China, they had a limited life expectancy, and I used to always replace them regularly, when the points were replaced, to avoid breakdowns.
Part of the problem is that no modern car has a condenser, so they are only made, as far as I can tell, by third rate suppliers, the big boys who make good stuff having no interest in that business. It is very easy for a back street operation in downtown Shanghai to procure cheap ceramic capacitors and stuff them in the right size of metal can, but they just can't cope with the repetitive peak current and voltage, as the original paper insulated type could.
#14 Carlos W
Carlos W
  • 10,115 posts
Posted 16 May 2013 - 09:03 PM
I've got an intermotor condensor I bought in a job lot. I listed it on eBay for 99p and it didn't sell
