I've been replacing the courtesy light switches as they were a bit old and crap, the passenger side didn't work and the driver's side was a bit tempermental, but now that I've converted the connections to spades and connected up the new switches, they no longer work at all.
I thought it might be the earth on the switch, but I cleaned up the area where the screw goes and the screw itself so I don't think it's either of those causing the problem.
I've checked all the fuses, as well as the connections under the dash to see if anything's fallen out and everything's fine. The permanent switch on the interior light itself still makes it come on so it's not a problem with the bulb or anything. Should there only be one wire going to each? Theres two going to the passenger side but only one to the drivers side.
I've also checked the connections with a multimeter and theres no voltage coming through the wires themselves, I assume they're supposed to be supplying some power when the switches are closed (doors are open)
