Im running a standard non ballasted DLB 101 12 volt coil on a mini 1000 that has electronic ignition, Spec for coil states for points use but Powerspark say can be used with their elctronic ignition kits.
Is this coil ok,or do i need a coil specifically for electronic ignition as I dont know make of my electronic ignition.
It doesnt have seperate black box on dizzy.
Reason I ask is that the wire from coil to fuse box melted other day, though small wire from dizzy to coil had earthed on metal dizzy bracket which may have caused short, or did heat generate in wiring causing it to weld to bracket.
Any help apprecaited. car needs a tune and bit jerky at low revs didnt know if coil was an issue.
