hi i recently bought a new speedo. is there a way i can transfer my current mileage over to the new speedo?
thanks in advance
Liam
Posted 17 May 2013 - 01:45 PM
thanks in advance
Liam
Posted 17 May 2013 - 01:48 PM
These guys can do it http://www.speedycables.com/
I replaced mine last year, and worried at MOT it would show up, but did not seem to, and that was a VOSA place!
Posted 17 May 2013 - 03:09 PM
is it legal to do this?
Rod
Rod
Posted 17 May 2013 - 03:24 PM
Yes, it would only be illegal if you attempted to pass it off as the actual vehicle mileage. You can alter the odometer reading by stripping the speedo down and turning the number drums manually, just ease them to the left to disengage from the ratchet- there's probably details online somewhere.
Posted 17 May 2013 - 07:17 PM
m not trying to alter the actual mileage of the car. I just want the new speedo to display the correct mileage that's all.
does anyone have any links as i cant seem to find any?
thanks
Edited by Lsurt95, 17 May 2013 - 07:20 PM.
Posted 17 May 2013 - 07:47 PM
Are you replacing just the speedo instrument itself, or the whole instrument pod? If you're replacing the whole pod and there's nothing actually wrong with your existing speedo, then it's quite an easy job to swap your existing speedo instrument across from one pod to another (thereby retaining your original mileage).
Posted 17 May 2013 - 08:58 PM
Im swapping out a Nippon Seiki 2 clock cluster to a 3. Or can i just transfer the printed circuit board and the tachometer over?
Posted 17 May 2013 - 09:26 PM
In which case you just need to take the plastic screen off of both pods, undo the two screws on the back of the casing that holds the speedo instrument into each pod and the speedo mechanisms should drop straight out, so that you can swap them over. Check out this previous thread where "Kam" explains exactly how to convert to a three clock cluster, with step by step photos. http://www.theminifo...=150365&hl=dash
Posted 17 May 2013 - 10:04 PM
ahh thanks that is perfect. And the Step by step in that thread are great.
thanks very much
