Does anyone know the adjustem in degrees if I turn the track rod end one full turn
Another question, if I adjust my tie bar to give 1/2 degree extra caster I assume this will toe out the wheels more and if so by how much
No replies to this topic
Also tagged with one or more of these keywords: suspension
Mini Technical Sections →
Problems, Questions and Technical →
Front Ride HeightStarted by Apeman85 , 18 Apr 2026 |
Shiny New BitsStarted by Murrayup , 15 Feb 2026 |
Rear Subframe Rear Mounting Pins Coated - Ok To Use?Started by EC123 , 28 Dec 2025 |
New Top Arm BearingStarted by Murrayup , 24 Nov 2025 |
Radius Arm Bracket Bolt - Just Spinning!Started by minicooper1.3i , 04 Aug 2025 |
