Mot Fail Gutted
27 replies to this topic
#1 station31
station31
  • 202 posts
  • Local Club: Caledonian Mini Club
Posted 17 May 2013 - 04:37 PM
I actually felt confident sort of prior, I fixed what I could, mainly electrics and the non running issue
It didn't pass not even close, its not a big list
001 Offside front headlamp too low
002 Nearside front streering rack gaiter split
003  Offside  front streering rack gaiter split
004 Rear sub frame corroded and seriously weakend.
005 Rear shock absorbers condition poor, confused by this one, I thought it was rubber cones ?
Its number 4 really got to me, I know its a big deal, Are Auto and manual rear sub frames the same? , I know the fronts are diffrent.
because an accident I had at work I'm pretty much on wheels now instead of feet.
I'm not able to pay a garage to sort this out nor really would I want to unless I really have to.
My question is really is this job possible in a lockup with friends giving me a hand, I've not changed a sub frame before
Graham
#2 waddle
waddle
  • 536 posts
Posted 17 May 2013 - 04:43 PM
on the back end you have the cones wich give it the "bounce" and then the shock absorbers also going from the radius arms to the wheel arch
steering gaters are a 10 min job
and the headlight the same
#3 Twisty
Twisty
  • 576 posts
with friends a lock up and some cold beers anything is possible, the items listed are all easy fixes with a little knowledge, hardest part will be the rear subframe change.
As for the rear shock question, these could well be warn and the rubber cones are good. A mini has rubber cones and shock absorbers in all four corners.
If you get stuck with any of the items on your list ask on here we will do our best to help, however i would strongly recommend a workshop manual if you dont already have one.
All the best
Steve
#4 Daz1968
Daz1968
  • 2,058 posts
Posted 17 May 2013 - 04:44 PM
Changing subframe is easy as long as all bolts come out and you find no body and heel board corrosion at same time
#5 babsbrown
babsbrown
  • 582 posts
Posted 17 May 2013 - 04:46 PM
Too be honest mate, I'm not great at mechanics, but removing the subframe seemed quite easy, I think it's a case of soaking the bolts a few days before attempting to take em off, in wd40, then use some heat on the bolts too to help with undoing them. Having a mate on hand to help you take the stubby off is a good idea just with the weight. Just make sure you have the rest of the body supported too, I made the mistake of undoing the bolts and realising I was supporting the car on axle stands which we're on the rear subby. On a lighter note, that list doesn't seem too bad, only the subframe really, but once you have that out of the way the rest should be easy. Good luck mate
#6 dow62
dow62
  • 355 posts
Posted 17 May 2013 - 04:50 PM
Get some plus gas or any other penetrating fluid (not wd40 ) on the 4 heel board bolts and go easy on them !
#7 adam_93rio
adam_93rio
  • 3,271 posts
Posted 17 May 2013 - 05:02 PM
The rubber comes absorb the shocks, the other things are dampers.
And why not wd40?
Edited by adam_93rio, 17 May 2013 - 05:03 PM.
#8 dow62
dow62
  • 355 posts
Posted 17 May 2013 - 05:08 PM
wd40 is just a general spray lubricant, not a dismantling penetrating fluid like plus gas.
#9 waddle
waddle
  • 536 posts
Posted 17 May 2013 - 05:12 PM
iv always been under the idea wd40 is made to displace water,  wich is not what your trying to do, also other oils (plus gaz) is also thinner so penatrates better
wd40 is good for in your dizzy mind
just my 2p
#10 station31
station31
  • 202 posts
Posted 18 May 2013 - 03:36 PM
Forgive the delay in getting back to the thread. I drove car home from MOT place yesterday, it seemed reludant to leave, but that, thats most likely points, just goes to show the bodywork may look allright on the bits you use, its bits you dont that can catch you.
My mates that have said they'd help, I've got a Haynes manual, we've looked at whats involved and there quite excited about the idea, I'm the nervous one, although having slept on it.  It doesn't seem as bad as it was yesterday, I've not been underneath yet, I do know it has been welded before, by a previous owner, which probably wasn't a great idea
I knew a biggie was comming eventually, got to admit there's a tinge of disapointment that Its not likely he'll be our this year
#11 tommy13
tommy13
  • 878 posts
Posted 18 May 2013 - 03:47 PM
Puzzled by the " Rear shock absorber poor condition" fail.  Is this the exact wording, and if so what exactly is wrong with them?
#12 sledgehammer
sledgehammer
  • 3,129 posts
Posted 18 May 2013 - 03:51 PM
I would get the penetrating oil on the subby bolts asap - esp the sill ones
you could (if brave) drill a small hole in the sill (3mm) in line with the bolts & insert the small straw
& blast the penetrating oil inside
longer it is on them - the better the chance of getting them out in one piece
best of luck
edit - poor shock condition could be heavy rust / leaking / bushes worn - so he just said in poor condition
shocks are easy to do if you are removing the subframe anyway
Edited by sledgehammer, 18 May 2013 - 03:54 PM.
#13 62S
62S
  • 1,248 posts
  • Local Club: You must be joking!
Posted 18 May 2013 - 06:16 PM
Re the heel board bolts - after having given them a while soaking in Plusgas or the like (and if using Plus Gas you want Formula A) try and tighten them a tiny bit (that means just a smidge or a tweak) before trying to undo them, this is often enough to break the rust seal.
#14 mini13
mini13
  • 3,811 posts
Posted 19 May 2013 - 10:04 AM
as above the rear subby is the worst bit, and the 4 bolts (2 each side) are going to be the worst, as above give them a soak in penetrating lubricant, plus gas ect, and go very gentle with them!!  if they are tight just ease them back and forth give them more lube, leave them for a bit and try again. If you break one off its NO FUN!
rear shocks are pretty cheap for std ones, so you may as well swap them while your doing the subby, the RH one is pretty easy but the LH one needs the tank removed which isnt that hard but a bit of a faff as you may have to drain it.
#15 station31
station31
  • 202 posts
Posted 19 May 2013 - 09:59 PM
I had a look underneath, at first the gaiters didn't look split but I did see after a prod a small tear in them, the subframe itself hmmm the passenger side looked pretty bad , It'll stick the photos on tommrow.
I did wonder if I need to do the shocks could it worthwhile converting to springs rather than rubber, making the ride less harsh and reduce my head smashing off the roof in at every bump
