Smoking Engine
14 replies to this topic
#1 don neate
don neate
    Starting My Mini Up
  • 2 posts
Posted 17 May 2013 - 04:54 PM
hi i ve got a 1974 mini with a 1275 engine with 1 3/4 carb which i put in, think engine is a 1980 ish when you start up from cold no smoke run ok but when gets to running temp it starts to smoke only on over run switch engine off when warm then start no smoke , it pulls well no knocks engine run nice on ticket over you can rev up when stop no smoke  had all 4 bores check,  compression was 150 on each bore i am thinking it some thing to do we head has anybody got any ideal i am thinking of buying another head dont want to waste money
#2 A-Cell
A-Cell
  • 1,610 posts
Posted 17 May 2013 - 04:57 PM
Could be valve oil seals. How much oil does it use? (Assuming no major leaks)
#3 minimuk
minimuk
  • 1,947 posts
Posted 17 May 2013 - 05:04 PM
Deffo valve stem seals gone...
#4 Marco1972
Marco1972
  • 822 posts
Posted 17 May 2013 - 05:18 PM
Valve seals are the cheapest option so change them first you will soon see if there past it when you remove the rockers n springs if there hard then there knackered
Usually a nice cheap n easy fix before spending big bucks on a new head
#5 nicky55
nicky55
    Starting My Mini Up
  • 1 posts
Posted 18 May 2013 - 07:24 AM
Can you repeat that in English? Or in any known language
#6 Willthewelder
Willthewelder
  • Validating
  • 161 posts
  • Local Club: Colchester Mini Club
Posted 18 May 2013 - 07:30 AM
We don't all speak 'Laandan. People give advice and help freely and for nothing which saves some people a lot of money by giving them the confidence to do the job themselves rather than a garage. It's a bit knob ish making a rather snide remark on your first post and without any valuable input into the topic.
#7 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 May 2013 - 08:04 AM
  Give the valve seals a go as they are cheap enough and the latest MPi ones are excellent, but I suspect you will find the valve guides are on their way out too.
#8 jpw1275
jpw1275
  • 2,803 posts
Posted 18 May 2013 - 09:51 AM
dont buy a head just yet.... as stated above and get yourself a haynes manual aswell as you will need it...;0)
#9 don neate
don neate
    Starting My Mini Up
  • 2 posts
Posted 18 May 2013 - 12:56 PM
hi thanks folks for the comments  think I will try and change valves steam and seals  and see what happens it does not drop oil it burns it 1/2 litr every 350 miles :proud:
#10 cal844
cal844
  • 9,713 posts
  • Local Club: TFMOC
Posted 18 May 2013 - 01:03 PM
valve stem seals mate!
#11 ACDodd
ACDodd
  • Mini Docs
  • 2,832 posts
Posted 18 May 2013 - 03:37 PM
Its a 33year old engine, start saving.
AC
#12 minidaves
minidaves
  • 4,933 posts
  • Local Club: mine
Posted 18 May 2013 - 04:18 PM
well said ac
#13 Marco1972
Marco1972
  • 822 posts
Posted 18 May 2013 - 05:36 PM
For our friend from London
Very happy to explain to you in SIMPLE ENGLISH if needed or get yourself a Haynes manual all will become clear.
#14 johnnyblaze
johnnyblaze
  • 189 posts
Posted 18 May 2013 - 08:27 PM
As said by everyone valve stem seals, but in my opinion id pull the head and have it rebuilt , new guides , valve grind and new seals that wont cost to much, that way you have a nice new head and if you do decide to rebuild the motor as AC was getting at , its only the the bottom end that you need to do , so its not such a big cost at one time.
#15 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 18 May 2013 - 10:07 PM
to be honest it doesn't sound like the valve seals to me, sounds more like worn bores/rings. the good compression test results being due to the oil sealing the rings, the lack of smoke when cold being due to the oil being thicker than when warm. bad seals/valve guides normally manifest themselves with smoke on start up.
that said the cheapest and easiest thing would be head issues, hopefully its as simple as valve seals. but certainly check the valves and guides for wear, the valve seats for pitting, maybe they could do with a lapping, and give the head a good clean, payen gasket and retorque after the first heat cycle and finger crossed
