I must be i guess, but i'm going to ask the question anyway.... Just got my Mini back from the body shop on Saturday - full respray and unfortunately it needed some panels that were not in the budget, but it got them anyway!.. The body shop is over from where i work so i popped in every so-often to take so progress pics, but now it's done and back home again.
A few electrical gremlins fixed and all seems fine now, but i opened the box with the new suspension cones in, and really wished i'd had time to fit them before the bodywork was done... but hey ho..
I used to work on Austin Rover cars as an apprentice, but it's about 28 years ago (the age of my mini!) since i last remember changing a cone, so i did a bit of research beforehand. The rears are a doddle, but i just couldn't remember if you have to remove the top arm to do the fronts. According to you guys, there seems to be a 50/50 split between those saying you have to remove the arm (uncle Haynes included), and those that say you don't.
So, before starting i rang up my garage mate who's fitted hundreds of 'em in his time and he says he's never taken the top arm off unless the threads strip in the cone.
Great, i'll try it without then and only take the arm off if i need to.... The Minispares compressor tool worked great apart from it didn't want to let go of the old cone, but could i get the very flat old cone out of the subframe? Not a chance!
I had 2 large pry bars on it, but there was no way it was going through that gap, and if it did there was even less chance of the new one going back in as it is 3/4 of an inch taller!!... So i took the top arm off and all went well after that!!
Tomorrow i've just got the left hand front to do, which it looks like i'll need to take the radiator out to get to the pin fixings unless you know some other way?
So, am i missing something ??... i must be 'because there's no way on my 1985 car that the flat front cone was going through that hole.... answers on a postcard !!! ![]()
If it's worked, i have attached a picture of my Mini doing its acrobatics in the paint shop!!!... i want this lifting gadget in my garage !!
