Hi all,
I'm quite a novice when it comes to things mechanical, so my mini is really a learning project for me. It's a '79 mini, and I'm having some problems getting the brakes sorted - it's a front/rear split system.
When I got it the brakes barely worked (you had to jam your foot all the way down on the pedal to get any braking at all). I've replaced calipers and shoes in the drums, changed all brake lines for copper excluding the 2 pieces that run from the 3 way t-junction thing (not sure what it's actually called) at the back to each rear wheel, and also one of the pipes that runs from the pressure regulating valve to the master cylinder. Front drums have also been completely replaced with a disc brake conversion kit.
A couple of weekends ago I tried to bleed the brakes, but still got loads of pedal travel and the brakes only worked with the pedal pushed right down. Today I replaced the master cylinder and tried bleeding the brakes again - I was using a one man bleed kit and had lots of trouble, which I assume was due to my incompetence. In the end I bought an Eazibleed kit (that works by using pressure from a spare tyre). I couldn't get it going properly at first, but then read that bleeding can be funny (in a non comedy way) if the brake adjusters aren't done up enough, so I tightened them until the rear wheels locked and tried again... it seemed to work a treat and I got clean, bubble free fluid from all 4 bleed nipples (bled in order according to Haynes manual). I then did my test... pushed the brake pedal and there was resistance. I think I even cracked a smile at this point thinking it was finally sorted. That soon faded when I went to bolt the front brake calipers on (I had them unbolted while I was sorting out something else with the wheel hubs, but they were bled with the bleed nipples at the top).
The problem is that the calipers are jammed as if the brakes are on, so the pads are clamped together on both front calipers. I read something about opening the bleed nipple (I guess to release some pressure) to free up the calipers, but although some fluid came out of the nipple it wasn't loads and didn't seem to make a difference. Could I have put too much pressure in the system with the Eaziibleed kit or something like that? It just seems like the brake pedal is pressed but it's not!
I thought I actually made some progress today only to find I'd gone from no brakes to permanent brakes. Any ideas would be much appreciated!
Cheers,
Strak
