Throttle. Pedal Sticking. Revving
3 replies to this topic
#1 miniallsort
miniallsort
  • 4,723 posts
Posted 18 May 2013 - 12:48 AM
I guys I have a auditing mini mayfair just noticed the throttle pedal. Is sticking. And revving. Going. By its self you have to press the throttle i
To stop it from revving
Any help please
#2 classicoop
classicoop
  • 182 posts
Posted 18 May 2013 - 01:11 AM
This happened to mine. Well not rev by itself. It just didn't return completely, leaving throttle slightly open and revving at around 2-3k.
A pedal return spring helped (cheap and quick, 30sec job) = didn't solve sticky/notchy pedal
I was using a new Minispares oem type non-coated cable, was sticky/notchy after driving a bit. Then tried using a Toyota nylon coated throttle cable, the threaded part (a bit longer than the stock one) is inserted on the bulkhead, the other fitting is cut and made to fit the white bit that slots into cable holder of the carb/throttle. = buttery smooth throttle
Check the basics I guess
1. sticky carb
2. cable (angle, condition etc etc)
3. pedal movement
#3 corrado vr6
corrado vr6
  • 678 posts
Posted 18 May 2013 - 07:39 AM
Make sure your engine earth is connected, otherwise your engine will be earthing through your throttle cable making it sticky/notchy as it'll heat up
#4 miniallsort
miniallsort
  • 4,723 posts
Posted 18 May 2013 - 02:01 PM
All sorted now guys. Throttle bracket. Was loose
