Tools For Drilling Holes For Guages
5 replies to this topic
#1 andy159
andy159
    Speedy fingers.
  • 837 posts
Posted 18 May 2013 - 08:19 AM
can anyone recomend a tool for drilling the correct size holes for my new dials, i shall need to drill 90mm holes and 52mm holes.
thankyou
#2 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 18 May 2013 - 08:31 AM
 Well I have always used an adjustable hole cutter.  It's a bit like a fly cutter really but it is a bit of a handful and not easy to get going especially in a hand drill, it takes a big chunk out if you push it too hard or go off line.  You can buy bimetal hole saws in a great number of sizes and the two you need would probably fit onto the same arbour so you would only need one of those.  Decent tool shops will have these, and there are a lot of sizes available at places like B&Q.  Or if you are fitting them to metal or thin plastic panels you could use something like a Q-max cutter.  These are great but I'm not sure if they make sizes this large and they would be expensive anyhow.
#3 Fast Ivan
Fast Ivan
  • 2,911 posts
Posted 18 May 2013 - 09:01 AM
adjustable hole cutter, as dan mentioned, would be how I would do it, a tip for this would be to clamp a piece of wood either side so that the hole in the dash is cut cleaner and helps prevent splintering if wood and digging in if metal. If you don't have the tools or inclination then you could chain drill it then file it to size.
Edited by Rob Mac, 18 May 2013 - 09:02 AM.
#4 dow62
dow62
  • 355 posts
Posted 18 May 2013 - 09:19 AM
Dont be tempted with a cheap hole saw set from the local market for £2.99 waste of money !
#5 acrowot
acrowot
  • 278 posts
  • Local Club: manchester minis
Posted 18 May 2013 - 12:19 PM
where abouts are u you could use my hole saws
#6 andy159
andy159
    Speedy fingers.
  • 837 posts
Posted 18 May 2013 - 12:23 PM
im in the midlands
