Help Getting Though A Mot
4 replies to this topic
#1 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
  • Local Club: Weston Mini Muckers
Posted 18 May 2013 - 09:22 AM
my wiring loom for my headlights is a mess lost my lights all of a sudden in between MOT tests anyone in the Weston Bristol area can have a look at it as im stumped of course will happily throw in some money for the time just need to get the car though MOT if anyone can help give me a ring on 07512321685
cheers luke
#2 corrado vr6
corrado vr6
  • 678 posts
Posted 18 May 2013 - 09:29 AM
Check fuses and the bullet connections behind the front grille
#3 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 18 May 2013 - 09:34 AM
I have its all a complete mess everything has been butchered from the previous owner :(
#4 callum2464
callum2464
  • 246 posts
Posted 18 May 2013 - 10:05 AM
what to do is as said before first check the fuses, then disconect the bullet connectors from the top corners of the engone bay for the lighting, and everything after that scrap, and get new wire, the wires coming out of the headlights themself should be a
blue and white wire - main beam
black - earth for the headlights i think
red - side lights
whatever the other colour is, is diped beam
these should be the same from the top of the engine bay
you then put a bullet conector on one end and take the wire to that correct wire on the headlight
hope this helped all you need is some new connectors and wires
#5 lucas1amps
lucas1amps
  • Just Joined
  • 587 posts
Posted 18 May 2013 - 12:49 PM
all sorted thanks
