Cooling System
Posted 18 May 2013 - 01:36 PM
Posted 18 May 2013 - 01:43 PM
have you pulled the heater valve open?
Posted 18 May 2013 - 01:51 PM
Posted 18 May 2013 - 02:21 PM
Posted 18 May 2013 - 05:09 PM
It's quite common for the pump not to deliver enough pressure to get water into the heater at idle. As said above take it for a drive to see if the flushing has done the trick.
Posted 18 May 2013 - 05:47 PM
Posted 18 May 2013 - 06:14 PM
I wouldn't worry about that at all, if the only sign of oil is a enough floating on the surface to make a rainbow but not enough to actually make a thick floating mess then there is only a trace present. It could have come from anywhere, including the container not being clean to start with.
Posted 19 May 2013 - 09:36 PM
Posted 19 May 2013 - 09:45 PM
Have you looked at the water pump?
Posted 20 May 2013 - 12:25 AM
Took the pipes to heater out so just got a pipe running from heater valve back to bottom hose and still the pipe ain't getting hot like it should sick of this don't know what to do now come on someone plz help of its going to be a call to mini sports see what they can come up with.
Disconnect pipe from heater valve to bottom of radiator hose. Run the engine with heater valve open. If water doesn't come out then passage is blocked/plugged up. Head gasket blocking passage?
