Rear Suspension Advice. What Should I Get
Posted 18 May 2013 - 06:27 PM
Posted 18 May 2013 - 07:09 PM
If you want coilovers you'd be better off with a beam type frame (technically it's not an axle)
If it's got cones up front why not stick with cones, hilos, up-rated adjustable dampers, lightweight radius arms, rear disk conversion... the list goes on and on haha
The lower the unsprung mass the better the ride and handling :)
Edited by smartie93, 18 May 2013 - 07:16 PM.
Posted 18 May 2013 - 07:20 PM
as above, if you want to fit coilovers, you may as well fit a beam type subframe replacement. it is advisable to beef up the top of your rear wheel arches to cope with the extra stress put on them from having the coilovers.
otherwise, just stick to the tried and tested route, new cones, hi-los, new knuckles, new mounting bushes for the subframe, and new dampers/shockers (personally i like GAZ adjustables as i have used them for years on a multitude of cars)
if you do stick with a conventional setup, im sure i dont need to tell you to give it a good coat of paint with hammerite as a minimum, or get fancy and spray it in some spanking bright colour in 2k paint. oh and cake everything in coppergrease!
