hi bought bottom arm poly bushes off minisport didnt come with sleeves is this because they arent needed for the poly bushes or should there be ones used with the bushes regardless
just not to sure
cheers
Posted 18 May 2013 - 07:24 PM
just not to sure
cheers
Posted 18 May 2013 - 07:44 PM
im pretty sure the ones i got from minispares a while ago were the same, and dont use a steel sleeve up the middle like the standard rubber ones have.
that steel sleeve is usually corroded onto the pin that goes through the bottom too and can be a pain to get it off
Posted 18 May 2013 - 07:46 PM
aww grand job just wasnt to sure!, ill get the grinder to them tomorrow then
Edited by smtaylor3, 18 May 2013 - 07:46 PM.
