Brakes Not Bleeding
Posted 18 May 2013 - 10:44 PM
My mini is a 1961 850, with drum brakes all round. I replaces the brake fluid in the master cylinder today, and then tried replacing the old fluid in the brake lines by unscrewing the bleed nipples in turn. I used an Ezee Bleed which I have use many times before with no problem.
There was easily enough pressure going through the master cylinder force fluid through. But no fluid came out of the nipples ( all four).
I removed the nipples and checked for blockages, and there were none, I could easily blow through them.
What could be the problem, could it be the bleed hole on each wheel slave cylinder?
John
Posted 19 May 2013 - 06:08 AM
Edited by Carlos W, 20 May 2013 - 07:15 AM.
Posted 19 May 2013 - 07:42 AM
has the flexy pipe out of the master cylinder collapsed internally ?
Posted 19 May 2013 - 10:00 AM
Have you tryed the two man system , its alot better than the eezibleed
Posted 19 May 2013 - 10:25 AM
Posted 19 May 2013 - 12:24 PM
Sounds like your ezee bleed is broken, try using the pedal and see if anything is coming out that way.
Posted 19 May 2013 - 05:13 PM
Hi
I managed to bleed the clutch OK, so the ezeebleed is working fine. There are no airleaks on the ezebleeed.
But I take back what i said about the brakes working properly. Today, I took the mini out for a drive, and brake pedal has to be pressed hard to make the car stop, coming up to roundabouts etc. Much harder than it used to be pressed.
Also, the master cylinder is the original one from 1961, so I reckon thats likely to be the problem internally. I think, for safety sake I will replace it with a new one.
Any thoughts?
John
