Hi All,
Mini Sprite '94 - rebuild going well. nearside sill to be finished today and then its time to put the new wing on.
I am going to plug weld along the inner wing and where it joins the side panel (A panel is it?) but whats the best way to join the curve below the headlight to the front of the car. If i drill the wing to plug weld it the problem will be one of access, the hole for the plug will be above the join and I wont be able to get the welding torch in there, so should I drill the front panel and plug weld up through to the wing?
I dont have a spot welder attachment - hence my questions.
Thanks,
Rod
Edited by rodandtom, 19 May 2013 - 08:07 AM.
