Shorter Gear Stick
10 replies to this topic
#1 MiniJimNI
MiniJimNI
  • 182 posts
Posted 19 May 2013 - 10:52 AM
I've been looking around and found that some folks have a shorted gear stick or modified so that its smaller and fits in to custom interior anyone done this can it be done???
#2 Globule
Globule
  • 1,134 posts
Posted 19 May 2013 - 10:57 AM
I don't understand the question. You looked around and found some people have already shortened it, but your asking if it can be done?
Any chance you mean a quick shift?
Edited by Globule, 19 May 2013 - 10:57 AM.
#3 MiniJimNI
MiniJimNI
  • 182 posts
Posted 19 May 2013 - 11:07 AM
Not a quick shift just seen in photos mate nothing on here
#4 Globule
Globule
  • 1,134 posts
Posted 19 May 2013 - 11:24 AM
Well then yes it can be done easily, just cut the stick to whatever length you fancy, re tap the thread and put the knob back on.
#5 alex-95
alex-95
    I am THE CLAMP MAKER
  • 6,078 posts
Have you got a picture?
#6 mini=love
mini=love
  • 211 posts
Posted 19 May 2013 - 12:14 PM
Yes you can cut them down, but have a feel first as it does change the throw quite a bit... might be best to fit a quick shift and shorten that, so the feel doesnt change so much...
#7 tiger99
tiger99
  • 8,584 posts
Posted 19 May 2013 - 05:38 PM
Actually, if you fit a quick shift and then shorten it, the change in feel will be more extreme, not less, and it is very likely to require too much force to be comfortable to operate. But it may be trial and error to find what is best, as everyone has their own ideas of what is required.
The only problem about cutting down the gear lever is that it is tapered, so reducing the end to the correct diameter to cut a new thread is a real pain. You would ideally put it in a lathe, but the lever is bent, usually at least. I don't know if a tool to do it properly exists, if so it might be a sort of outside-in reamer, a tube with cutting blades on the inside, or something like a die but with plain cutting edges instead of threads. You would use it to skim down the diameter so it was parallel and of the correct diameter and then thread it with a die in the usual way. If someone knows of such a tool, please enlighten us.
Many people cut and weld them, probably to avoid the problem of making a parallel section which can be threaded.
#8 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 May 2013 - 05:42 PM
  Do you mean cars with the selector housing moved to the inside of the cabin?
  As said above, if you cut down the stick the throw will be shorter anyway and a short shift kit along with a shorter stick would be a handful.  The problem with simply cutting down the stick and leaving the housing under the car is the stick will be very hard to reach from the driver's seat.
#9 MiniJimNI
MiniJimNI
  • 182 posts
Posted 19 May 2013 - 11:52 PM
Some interesting points i saw it on a custom build awhile ago and lied the idea! Food for thought!
#10 Ethel
  • 26,581 posts
Posted 20 May 2013 - 12:02 AM
It wasn't just a centre console & gaiter over a standard stick?
I reckon the easiest way would be to make up a guide bush so you could  cut a section out, drill the ends concentrically through the bush, and dowel them back together.
#11 The Principal
The Principal
  • 765 posts
Posted 20 May 2013 - 05:15 AM
I have a modified gear lever in the garage, when I bought a remote box the guy had taken about 3 inches off the top then glued a modifed gear knob on top. I have never used it so cant comment on what is like to use
