Diff Housing Had It?
28 replies to this topic
#1 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 11:35 AM
Spent all week stripping out the 'box and i've come to wash it out today but i've found this....looks like it's took a chunk out of the rod steady housing and also a split down the side of it, do i need a new diff housing in which case i'll just get a recon'd box, or can i get away wth it? Cheers
http://www.flickr.co...N05/8753962374/
http://www.flickr.co...N05/8753962330/
http://www.flickr.co...N05/8753962268/
#2 mini=love
mini=love
  • 211 posts
Posted 19 May 2013 - 12:03 PM
That is just a steady the gear linkage, so should be ok, but obviously not ideal...
#3 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 12:06 PM
yeah, just not sure if i should be using it or not, i'd rather not have to go buy another casing  :unsure:
#4 mini=love
mini=love
  • 211 posts
Posted 19 May 2013 - 12:07 PM
As long as its just the external part of the casing and hasnt cracked through anywhere then it should be fine...
#5 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 12:25 PM
yeah it's just external, no cracks on the inside. maybe replace the 'metalastic' bush though?
#6 Ethel
  • 26,581 posts
Posted 19 May 2013 - 12:28 PM
My guess is a combination of corrosion & freezing water has blown the lug off. A welding repair looks like the best option.
#7 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 12:47 PM
i've decided to use it, i'll see what i can do. cheers guys.
#8 mini=love
mini=love
  • 211 posts
Posted 19 May 2013 - 04:32 PM
Yea i wouldnt worry about it to much, its not really put under much stress as the gear linkage is on rubber bobbins aswell...
#9 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 May 2013 - 05:30 PM
  Definitely get it repaired.  it may not be under much stress but without the gear selector steady rod being properly anchored gear selection become very tricky and boring.  Not worth scrapping the casing (you cannot swap to a used diff housing any more than you can swap the main bearing caps in the engine for used ones so the whole casing would be scrap) but as above get it welded up.
Edited by Dan, 19 May 2013 - 05:30 PM.
#10 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 06:28 PM
will do, what do you think the best option is, weld a small piece of aluminium between the snapped bit to brace it?
#11 Dan
Dan
    On Sabbatical
  • 21,354 posts
Posted 19 May 2013 - 06:33 PM
  Yes just weld some ally in to the gap to remove the possibility of the bush pulling out of place one day and give it some strength.  You could probably bond a piece in to be honest.  Then just file the edge of the fitted piece to the right shape and fit a new bushing.
  Before you weld, remember the bush is rubber!
Edited by Dan, 19 May 2013 - 06:34 PM.
#12 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 06:37 PM
no worries, yep i've took the old one out now anyway, definitely need a new'un! i'll have a go at tig welding it tomorrow at work, fingers crossed! cheers
#13 A-Cell
A-Cell
  • 1,610 posts
Posted 19 May 2013 - 06:41 PM
2 part epoxy would repair this IMO
#14 grahama
grahama
  • 2,442 posts
Posted 19 May 2013 - 08:20 PM
just a thought
http://www.ebay.co.u...=item5af1173968
#15 Chappb
Chappb
  • 268 posts
Posted 19 May 2013 - 08:26 PM
just a thought
Haha yeah thanks i looked at that earlier, but as Dan says, gearbox casings and diff housings are matched as a pair so another diff housing might not be a perfect fit.
I'll have a go at welding it tomorrow and see how that goes anyway. If that doesn't work out then i'll try some bonding solution.
