Hi all,
just connected this up to the box and got the in car bit bolted in but it seems to be offset. ie the linkage rod goes at an angle to the gearbox not parallel to the tunnel. I am assuming that this is to accommodate the exhaust in that area, or have I really messed up somewhere ??
It does however change gear into all gears and reverse as it is !!!
thanks,
Graham
