Removing Roof Decals - Faster Way?
Posted 19 May 2013 - 08:15 PM
I'm trying to remove my roof decal or two years. I've referred to several threads on here which recommended using a hairdryer. Well that works, but its awfully slow.. I spent an hour and I'm not even a quarter done...! The decal keeps splitting as I peel it back.
Is there a faster/easier way to do this? Appreciate any advice on this, tks.
Posted 19 May 2013 - 08:28 PM
If they came off easily they wouldn't be much good.
Posted 19 May 2013 - 08:40 PM
A more powerful heat gun will get them off faster but if you're not careful you'll also take the paint off.
It's best to just take your time.
Posted 19 May 2013 - 08:42 PM
Park it in the sun and do it on a hot day
Posted 19 May 2013 - 09:48 PM
i used a kettle to get my decals off, sounds daft but they peeled off in no time ![]()
Posted 20 May 2013 - 10:37 AM
What part of the kettle did you use ??
Posted 20 May 2013 - 12:29 PM
What part of the kettle did you use ??i used a kettle to get my decals off, sounds daft but they peeled off in no time
Well, i think I've heard of these kettles with specialized spouts that can be used to peel off the decal
Anyway thanks for the replies guys, much appreciated. A hot sunny day + hair dryer and a bikini should do the trick.
Posted 20 May 2013 - 12:51 PM
Posted 20 May 2013 - 12:58 PM
I just boiled the kettle let it cool down a bit then just poored it over my decals, hardly left any sticky behind
Posted 20 May 2013 - 01:27 PM
Try some WD40 as well as heat.
I did think about using white solvent but decided that it wouldn't help as it won't penetrate the vinyl decal. am i wrong?
Edited by stonecow, 20 May 2013 - 01:27 PM.
Posted 20 May 2013 - 01:36 PM
just stick at it if you start messing with really hot heat guns you could mess your paint up, its painfully slow but just keep going ![]()
Posted 20 May 2013 - 06:39 PM
As you ease the vinyl off, a squirt of WD40 under the vinyl will penetrate the adhesive and make I a bit less stick on the paint. It's still a slow messy process!
Posted 21 May 2013 - 07:31 AM
Posted 21 May 2013 - 08:11 AM
Posted 22 May 2013 - 12:47 AM
I can't remember where but I saw a video of a guy removing decals. (This was on Petrol's MPi restoration thread, not a video after all) It was mentioned that heating from underneath was the best way as it doesn't weaken the vinyl as much but does heat up the adhesive.
+1 for WD40 removing sticker residue also, I tried using nail polish remover once, and it worked well but ended up taking the shine off paint. WD40 was just as successful if not more and it's not dangerous to paint (to my knowledge)
Cheers, Jack
Edited by jackgreen91, 22 May 2013 - 09:43 AM.
