6 Point Roll Cage How To Bolt In
5 replies to this topic
#1 minilee94
minilee94
  • 3,523 posts
Posted 20 May 2013 - 06:28 AM
I'm thinking of getting a 6 point roll cage in my mini but how does the front part bolt in we're does it bolt to thanks
#2 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 20 May 2013 - 06:48 AM
bolts through the floor with a big spreader plate
#3 minilee94
minilee94
  • 3,523 posts
Posted 20 May 2013 - 06:57 AM
Okay thank you any one gt any pics and what you mean spreader plate
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 20 May 2013 - 08:24 AM
it's just a thick rectangular bit of metal used to spread the load
with out it the cage legs could just punch through the floor or pull the bolts through the floor
#5 Tahiti Joe
Tahiti Joe
  • 663 posts
Posted 20 May 2013 - 08:41 AM
As said, the cage uses spreader plates mounted through the floor. Internally the plates should be welded to the sills/floorpan and be made of 3mm steel. Its also a good idea to use an external plate to reduce any chance of the bolts pulling through in the event of a roll.
Is this for competition use?
#6 minilee94
minilee94
  • 3,523 posts
Posted 20 May 2013 - 07:50 PM
Okay thank I see what you mean I just dont want my mini to have big bolts hanging out the bottom
And no it's for road use it a weekend road car
