Setting Up Twin Hs4
Posted 21 May 2013 - 05:35 AM
1330cc
Kent 286
big valve head
twin HS4
I'm running number 7 needles at the moment, and was just wondering if these are correct?
also the plungers on each carb that lift up the inner of the carb, what should happen when these are lifted? Should car idle speed increase slightly? as it isn't doing that, and I've been told it should, so too rich?
sorry for all the questions, thanks in advance!
Alex
Posted 21 May 2013 - 10:54 AM
Hard to tell exactly what needles without dyno etc , but the 7 s will be close ( just some caution about running to0 rich for running in) .. at idle , if you push the plunger it momentarily lifts the carb bell - if idle momentarily rises and then falls - mixture is correct. if it rises and stays elevated then too rich, if it stumbles or labours, stalls etc too lean - be careful though as you normally do this when engine fully warm and without airfilters and without vacuum /breathers connected - the filters can change the mixture -- but without having MOT to worry about over in AUS - we can just set the idle a bit higher ( slightly lumpy at 1100 say) ---that shouldn't have any impact on 3 thousand revs - that could be ignition timing
Posted 21 May 2013 - 12:27 PM
