Amp Confusion
7 replies to this topic
#1 Miniowner123
Miniowner123
  • 987 posts
Posted 21 May 2013 - 06:44 PM
been doing alot of reading but still confused about amps, basically i got my eye on 2 of these -
http://www.caraudiod...ro-gzhw30x.html
but cant figure out that if run 2 of these in parallel how many ohm do i end up with?
also what type of amp would i need to run these? what would people recommend?
thanks and sorry if its a stupid question
#2 freshairmini
freshairmini
  • 1,718 posts
Posted 21 May 2013 - 08:13 PM
If you run two 2 ohm speakers in parallel they will be running at 1 ohm.
That sub is a dual voice coil. So if you wired the two coils in parallel on both subs it will be running 0.5ohms (I think).
Either way be it 1 or 0.5ohms you will struggle to find an amp that will do that or it'll just be very expensive!
Edit: looking at a ohm calculator online, I believe if you where to run the coils in series and the two subs in parallel you could get them running 2 ohms which would make it easier to find a suitable amp.
Hopefully someone else will confirm what I said to be true! So don't take my word as final, haha.
Edited by freshairmini, 21 May 2013 - 08:21 PM.
#3 Miniowner123
Miniowner123
  • 987 posts
Posted 21 May 2013 - 08:52 PM
thanks, making the ohm thing make more sense :-)
may have to go for different subs if this starts working out too difficult for me to understand :shy:  hopefully someone can can confirm and point me in the right direction
#4 Miniowner123
Miniowner123
  • 987 posts
Posted 24 May 2013 - 02:16 PM
well i done a little more reading and finally ended up buying two of these -
http://www.caraudiod...dio-12w3v3.html
just noticed the price has gone back up, i got them for £179.99 each :-)
i was going to order a alpine pdx amp to power these but was working out rather expensive so i've left it until i start on installing them bits, at the mo i'll just work on getting the sub enclosures made and fitted
#5 freshairmini
freshairmini
  • 1,718 posts
Posted 24 May 2013 - 06:57 PM
Nice, jl do some great subs. Got a 10w3v3 and its brilliant, what's better i got it for £70!
#6 Miniowner123
Miniowner123
  • 987 posts
Posted 24 May 2013 - 07:06 PM
bargain! think we both done well then :-)
now for a set of components, i do have some focal 3 ways but using them in my other car so i have my eyes on these -
http://www.caraudiod...-esk163l.5.html
seems to be the only sort of thing in that price range, cant find no bad reviews just good
#7 freshairmini
freshairmini
  • 1,718 posts
Posted 25 May 2013 - 09:58 AM
From what I heard of them hertz do some good speeakers in that price range. Focal as well, I think their K2 range is a similar price range and sound pretty good. Would be a good idea to see if you have a listen of them. http://www.highdowncaraudio.com/ are down in worthing do hertz as they are a fourmasters shop.
#8 Miniowner123
Miniowner123
  • 987 posts
Posted 26 May 2013 - 03:33 PM
didnt even know they were nearby, shows how well i know the area
took a look on their website, didnt have the same hertz ones, so i looked elsewhere and at the car audiodirect price seemed like a good deal so i went ahead and ordered them :-) it'll be a while before i can test them out as i have alot of interior work to do to get them fitted plus i still need to order my amps
