How Do I Tell What Block I Have?
Posted 21 May 2013 - 07:08 PM
Cheers Jake
Posted 21 May 2013 - 07:11 PM
If you look at the back of the block it should have no tappet chest access panels there
look for a riveted plate on the top face..
If its a mini block
number beginning
99 = 998
12 = 1275
10 = 1098
If no plate look at rear of block if there are 2 rectangle plates or even 2 holes where there should be plate, strong chance not a 1275 but not definitive
Posted 21 May 2013 - 07:15 PM
All large bore castings have 2 core plugs on the rear end of the engine above the clutch, where the steady bar attaches. All small bores have only 1.
Posted 21 May 2013 - 08:56 PM
Posted 21 May 2013 - 09:04 PM
Apologies, you're right. I've been reminded of that previously too.
Posted 21 May 2013 - 09:05 PM
Cheers Jake
Posted 21 May 2013 - 09:18 PM
Can't you measure the bores?
Posted 21 May 2013 - 09:26 PM
Jake
Posted 21 May 2013 - 09:28 PM
I'd sort of just assumed you couldn't for some unknown reason, like the engine was built and you didn't want to open it but if it really is just a block it would be quite easy!
Posted 21 May 2013 - 10:04 PM
