How To Change Thermostat?
10 replies to this topic
#1 Mini Ali
Mini Ali
  • 12 posts
Posted 21 May 2013 - 07:51 PM
How do you change the thermostat. Its a 1980 hl auto with a 1275cc engine. I cant seem to get at the thermostat because the housing is attached. How do you get it off. I've undone the 3 bolts but it still wont budge
Any help much appreciated.
#2 stocky
stocky
  • 338 posts
Posted 21 May 2013 - 07:58 PM
Assuming you have taken off the bracket for the radiator too. Then its a case of wiggling the housing until it comes clear. The gasket can be holding it all together
#3 v8rumbler
v8rumbler
  • 68 posts
Posted 21 May 2013 - 08:01 PM
a light tap with a wooden mallet can help
#4 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 21 May 2013 - 08:04 PM
They can really stick themselves to the studs, be careful not to lever something between the iron cyliner head and the alloy housing to pry it up, a few small taps should work!
#5 Mini Ali
Mini Ali
  • 12 posts
Posted 21 May 2013 - 08:08 PM
Thanks. I have taken the bracket off but there is a a square cover over the housing and I cant get this of.
#6 stocky
stocky
  • 338 posts
Posted 21 May 2013 - 08:14 PM
Can you post a picture? I'm not sure of any square cover but I'm not familiar with auto's
#7 Mini Ali
Mini Ali
  • 12 posts
Posted 21 May 2013 - 08:18 PM
I cant get a picture atm as the car is at a lock up as its being restored. Wont be able to get one till the weekend and it is an auto.
#8 maccers
maccers
  • 1,880 posts
  • Local Club: LSMOC
Posted 21 May 2013 - 08:25 PM
I am sure the theromstat housing is the same as a manual, ie round-ish. When I was servcing a friends car for the first time after he bought it, I ended up breaking it away in bits it was that stuck, but I had a spare in my garage I used that was in good nick. It must have been the original, it was very warped and backfilled with silicone as a temp fix  / bodge.
#9 Mini Ali
Mini Ali
  • 12 posts
Posted 21 May 2013 - 08:27 PM
Thanks for the help
#10 smev
smev
  • 162 posts
  • Local Club: P&S MOC
Posted 21 May 2013 - 08:29 PM
Are you talking about the engine steady bracket?
#11 mini=love
mini=love
  • 211 posts
Posted 21 May 2013 - 08:36 PM
Can almost guarantee its just the bolts in the thermostat housing have rusted, give it a good soaking in penetration oil and give it a few taps till it comes loose.
In a few cases i have had to cut the aluminium housing, round the bolts to get it off.
